Thread: sheet set problem
    2012-04
    3
    Red face sheet set problem
    hi, i already build sheet system in cad 2012,and when I double-click the sheet on which i want to place a viewport,then click the model views tab,right-click the named view that I want to use,and choose place on sheet, now ,the problem comming, I find all layer which I alreay off or freeze will on, and I will do again to off or freeze layer which I don`t want show in drawing, so , what I can do? Did there have any way to keep my option on layer set?
    thank!!
    2016-02
    Sydney, Australia
    512
    Default Re: sheet set problem
    Select "Layers" in the active viewport, and in the top left of the dialogue box, you'll see the button to save the layer set.
  1. 2013: Sheet Name capitalization problem
    By shannonstandish in forum Revit Architecture - General
    Last Post: 2013-01-18, 08:18 PM
  2. sheet problem
    By whittendesigns in forum Revit Architecture - General
    Last Post: 2007-02-10, 11:41 PM
  3. Problem with sheet sets
    By gus1 in forum ACA General
    Last Post: 2005-11-10, 03:36 PM
  4. yet another sheet problem in PN
    By david_peterson in forum ACA General
    Last Post: 2005-05-06, 01:42 AM
  5. Sheet problem?
    By aliya14 in forum Revit Architecture - General
    Last Post: 2005-03-29, 03:30 PM
