Thread: Linked project always goes to Level 1
    2007-01
    13
    Post Linked project always goes to Level 1
    I have a typical unit plan .rvt that needs to be linked to central.rvt where it occurs at several levels. I could easily place,move or copy them to the levels I want.
    and I could schedule just about everything I want from that link to my central. Only one problem, I could not sort them by Level, because those link units and everything in it all show up as Level 1 in the schedule, even though I inserted them in, say, Level 5.
    Anyone find a workaround or am I missing something?
    AUGI Addict jsteinhauer's Avatar
    2007-09
    Madison, WI
    1,029
    Default Re: Linked project always goes to Level 1
    Check that element's instance properties. Level might not be automatically assigned. I have found this is the case with face based families as well.
    Cheers,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
  1. Project Level/Shared Level Problem
    By Andrew Dobson in forum Revit Architecture - General
    Last Post: 2008-11-26, 10:34 AM
  2. Filter by level in linked schedules
    By NKramer in forum Revit Architecture - General
    Last Post: 2008-06-12, 06:00 PM
  3. Wall height linked to the Project Level Height
    By tomislav.zigo in forum ACA/AMEP Tips & Tricks
    Last Post: 2006-07-26, 04:15 PM
  4. Visibility of level lines in linked files
    By Joef in forum Revit Architecture - General
    Last Post: 2006-05-04, 06:11 PM
  5. Level Datums in Linked Files
    Last Post: 2006-05-01, 03:12 PM
Tags for this Thread
