Thread: TTF fonts not appearing
    2012-04
    Default TTF fonts not appearing
    I etransmitted my file at the office in order to work on it at home over the weekend in Autocad 2010, and the ttf fonts are missing. They are properly installed in the Windows\Fonts folder but are not showing up in Acad. In the txt file included in the etransmitted zip, there is the following note about font substitions:
    The AutoCAD variable FONTALT was set to:
    C:\Users\*****\appdata\roaming\autodesk\autocad 2011\r18.1\enu\support\simplex.shx
    Please make sure that the FONTALT variable is set to this file or an equivalent before opening any drawings. All text styles with missing fonts are automatically set to this font.
    Any help on how to correct this? Thanks.
    0,0,0 The Origin
    8,570
    Default Re: TTF fonts not appearing
    Quote Originally Posted by asg6000521094 View Post
    Do you mean that the font files are missing or drawing text that uses ttf fonts is missing?
    The equivalent path on your home machine will probably be -
    c:\Users\your username\AppData\Roaming\Autodesk\AutoCAD 2010\R18.0\enu\Support\simplex.shx but what are you seeing where you should be seeing text in ttf fonts? The fact that the fonts are installed in \Windows\Fonts means acad should be using them.
    Also, is this a 3d problem?
    2012-04
    Thanks for replying... No, this is not a 3d problem; I didn't understand the forum descriptions, sorry about that.
    But I think you can help me solve this! When I open the cad file, the fonts are all changed to huge standard font (I think), when they used to be the right size Arial style on my office workstation. I need to do text editing and create new text but the placement looks all wrong. Inthe winddows font folder, I have the arial font, but it looks like the other two ttfs are missing. Is this the problem?
    The following files were excluded from the transmittal:
    acad.fmp
    Fonts\simplex.shx
    Fonts\txt.shx
    Fonts\arial.ttf
    Fonts\UNIVER.TTF
    Fonts\UNIVCD.TTF
    Fonts\ROMANS.SHX
    Fonts\BOLD.SHX
    2012-04
    Got it! a quick visit to http://www.findthatfile.com/ and it looks OK now. Thanks!
    0,0,0 The Origin
    8,570
    So UNIVER.TTF and UNIVCD.TTF were not installed on your machine?
    Glad you fixed it.
  1. 2013: Volume in Schedules appearing and not appearing
    By Chris.Partin in forum Revit Structure - General
    Last Post: 2013-02-20, 04:19 PM
  2. 2010: TTF fonts not appearing
    By asg6000521094 in forum AutoCAD 3D (2007 and above)
    Last Post: 2012-04-22, 10:34 PM
  3. Different fonts have started showing up as default AutoCAD fonts
    By jackie.112886 in forum AutoCAD General
    Last Post: 2006-05-15, 11:02 PM
  4. DWF loses protected fonts - download fonts option?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-03-25, 12:01 AM
  5. shx fonts to true type fonts
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-03-31, 02:53 PM
