Thread: Metal Stud Wall
    2011-11
    12
    Default Metal Stud Wall
    Trying to create a section of metal stud wall in RS 2012.
    Load some structural framing componets but having a difficult time manipulating them, i.e. turning the bottom channel upside down to use as a top channel. Have disconnected from the ref. plane and use every tool
    in a futile attempt to turn the channel upside down.
    2002-09
    Madison, WI
    5,688
    Default Re: Metal Stud Wall
    You should be able to set the "cross sectional rotation" unless that's one of the families that adesk screwed up. I can't remember. I know we had to modify a bunch of their families to work correctly. Some we just had to add additional types for LLV vs LLH.
    Anyway, adjust the cross-sectional rotation to 90, go to a section view and use the align tool to set the elevation since you want the top of the channel and not the centroid.
    Hope this helps.
  1. Light Gage Metal Stud
    By Thomas Maleski in forum Revit Structure - Families
    Last Post: 2010-11-30, 12:28 AM
  2. Metal stud DB rotate issue
    By beardking in forum Dynamic Blocks - Technical
    Last Post: 2010-06-08, 05:59 PM
  3. Metal studs/Woods stud layout Tools
    By pugander in forum Revit Structure - Wish List
    Last Post: 2009-09-18, 12:03 AM
  4. Metal stud at the end of the wall as well as repeat every 16"
    By spddesigns in forum Dynamic Blocks - Technical
    Last Post: 2007-05-24, 02:59 PM
  5. 6" Metal Stud Wall @ 16" o.c.
    By aokane in forum Revit Structure - General
    Last Post: 2006-03-08, 04:21 PM
