Results 1 to 8 of 8
Thread: Blocks, creating and using.
    2006-10
    26
    Default Blocks, creating and using.
    Instead of drawing the arrow and placing the letter at either end of a section line I was thinking of putting these into blocks, one for each end. Is this the way to go? I have tried creating a block following what instructions that I can find but when I come to insert the block it is nowhere to be found.
    What are the step by step instructions for creating?
    100 Club StDoodle's Avatar
    2008-01
    129
    Default Re: Blocks, creating and using.
    First, yes, this is probably the best way to go; if you plan on using something multiple times, a block is generally the best bet. Second, once you get the hang of the basics, you might want to check out integrating it with the Sheet Set Manager. (Good link here: http://images.autodesk.com/adsk/files/intro.pdf)
    It's hard to know what went wrong without knowing what instructions you were following, but one guess is that you created the block, then went to use it in another drawing but it wasn't there. Like all other AutoCAD entities, blocks are only available in drawings they've been placed in. Several approaches are available to deal with this; you can create a template file that already has your blocks in it (simply save a pre-setup drawing as a .dwt file), you can Design Center (command line: adcenter) to grab blocks and other stuff from existing drawings, or you can create a tool palette that will automatically grab blocks from a drawing through the Design Center in the background. Or, when in doubt, copy & paste!
    100 Club heinsite's Avatar
    2005-11
    Kona, Hawaii
    137
    Quote Originally Posted by StDoodle View Post
    [snip]... or you can create a tool palette that will automatically grab blocks from a drawing through the Design Center in the background.
    Speaking of the Tool Palette... when you go there be SURE to check out all of the ready made blocks for sectioning. You may find something there that may be easier and more functional than making something new. Look in the Annotation tab of the standard tool palettes.
    Dave.
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    548
    Quote Originally Posted by alan.123099 View Post
    Nowhere to be found on the list, or on the drawing area after you insert it?
    if the first, you were not successful in creating the block.
    Its as simple as 1. Entering Name 2. Picking base point 3. Selecting Objects
    Then Press OK.
    if the latter, I suspect, your base point (set in step 2 above) is way far from the objects in the block. Try picking it snapping to any object included in the set (step 3). Then watch out for the scale upon insertion and of course the active layer & layers used by the objects inside the block (might be off).
    Side Note: Its a good (or standard) practice to put all objects in the block to layer 0. Layer 0 acts as a transparent layer and let the objects inside the block to inherit the properties of the layer where the block is being inserted to.
    PS: There is a quicker way of creating a block.
    1. Copy Objects (Ctrl+C)
    2. Paste as Block (Ctrl+Shift+V)
    The result is a randomly named block (starts with "A$") with basepoint set on the lower left corner of the objects' bounding box. You can always rename the block later with the RENAME command.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2006-10
    26
    Since I have closed and reopened AutoCAD, the blocks now appear in the drop down list under Insert/Block.
    Thank you all for your response.
    2006-10
    26
    I replied too soon. When I start a new drawing, the blocks that I have just created do not appear in the drop down list under Insert/Block. (I have other blocks listed that were created many years ago for me by others). The blocks are listed when I'm in the drawing that I used to create them. How do I get these blocks to list when I'm in other drawings?
    0,0,0 The Origin
    8,028
    A block only exists inside the file in which it was created until you do something about it.
    One thing you can do is use the WBLOCK command to create a separate file for each block - those files can then be inserted into any other drawing file.
    ANY drawing file can be used as a block simply by using the INSERT command.
    You could use the Design Centre (ADC) to collect existing blocks from within the file that already contains them.
    etc..
    Beware - do not create a block inside a file with the same name; you won't see a problem at the time but you won't be able to insert the file into another file.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Cairo - no, not Illinois
    2,728
    it gets even weirder if a drawing ends up xreferenced to itself.... damifino how that happened.
  1. creating a catalog of blocks
    By earnold in forum Software
    Last Post: 2009-08-21, 07:05 PM
  2. creating blocks
    By cheryla in forum Impression - General
    Last Post: 2008-11-12, 09:24 PM
  3. Replies: 3
    Last Post: 2006-09-12, 11:17 AM
  4. Creating Tool Palette from Blocks
    By mgagnon in forum ACA General
    Last Post: 2005-04-06, 09:00 PM
