Thread: TFRAMES
    2008-07
    Laurel, Maryland
    13
    Question TFRAMES
    Hi, everybody-
    We recently installed 2012 and are still working out a few glitches. You all have helped us immensely already, but I have another one. The "TFRAMES" command will turn the frames on but not off. I'm sure there is some simple solution to this, but I don't know it. Any suggestions? Thanks!
    Meredith
    2002-09
    Madison, WI
    5,687
    Default Re: TFRAMES
    tframes has kind of been replaced by the imageframe sys var. There's 3 options.
    0 = image frame not displayed for plotted - but reappears during selection preview or object selection
    1 = displays and plots image frame
    2 = (In theory) displays image frame but doesn't plot.
    I say in theory, because I'm not sure what the relationship is between imageframe and the tframe toggle, but I think one overwrites the other and both need to be set correctly.
    However I could be wrong. Hopefully one of the expert guys can explain a little more, but I hope this helps in the meantime.
    2005-06
    in the upper right corner
    3,507
    Default Re: TFRAMES
    Quote Originally Posted by david_peterson View Post
    I don't know about TFRAMES or ACAD 2012, but in 2011, sometimes if you go from Imageframe 1 or 2 to Imageframe 0, the frame doesn't always go away.
    The only work around I've found is to swich back to Imageframe 2 and then back to 0 and it usually makes it go away, also try REGENALL.
    Just my two cents on the subject.
    2001-12
    St. Louis
    5,407
    Default Re: TFRAMES
    The FRAME setting overrides the following sysvars:
    IMAGEFRAME
    DWFFRAME
    PDFFRAME
    DGNFRAME
    XCLIPFRAME
    also setting
    3 = individual settings vary for each of the types of referenced files
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Frames and Tframes
    Last Post: 2016-07-22, 10:25 PM
  2. TFRAMES
    By avn in forum AutoCAD Civil 3D - General
    Last Post: 2009-10-06, 03:02 PM
  3. Image frame displays partially when tframes set to off
    By bcowper in forum AutoCAD Plotting
    Last Post: 2005-12-23, 10:15 PM
  4. Tframes not working as per normal...
    By lem_102074329 in forum AutoCAD General
    Last Post: 2005-12-08, 04:39 PM
  5. TFrames command produces Error
    By neilcheshire in forum AutoCAD General
    Last Post: 2005-10-31, 02:10 PM
