Thread: Any way to base roof only off exterior of core?
    2005-08
    99
    Question Any way to base roof only off exterior of core?
    I am fairly new to Revit, the one thing I have been having problems with is the roofs. As I am adding or modifying wall components (stucco, shingle etc.) it is causing my roof to explode, with many many join errors. I traced it down to moving the roof "base" over the new exterior finish material. the roof is very complex, which is a major pain and takes quite a while to bring the roof back into its correct position. The wall sheathing and exterior finish materials are put outside the core of the wall with the stud being the only item within the core. Is it possible to have the roof based only on the core and not the exterior finish?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Any way to base roof only off exterior of core?
    When creating the roof by foot print, use the pick wall tool and check the box "extend into core".
    Scott D. Brown, AIA
    BECK
    2005-08
    99
    Quote Originally Posted by sbrown View Post
    Thank you!
  1. 2014: TJI roof w/ exposed backspan exterior rafters, Need Help
    By chadsalter548393 in forum Revit Architecture - General
    Last Post: 2014-06-07, 01:54 PM
  2. Exterior Wall/Core Model Linking
    By psimpson.159751 in forum Revit - Platform
    Last Post: 2008-05-05, 03:17 PM
  3. Exterior wall finish & Roof slice
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2008-03-13, 04:05 AM
  4. Roof problem : trss roof does not intersect exterior wall correctly
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2008-01-29, 05:37 PM
  5. Roof core
    By chad_middlemis in forum Revit Architecture - General
    Last Post: 2005-01-11, 01:09 AM
