Thread: Metal Stud Wall
    2011-11
    11
    Default Metal Stud Wall
    Trying to create a section of metal stud wall in RS 2012.
    Load some structural framing componets but having a difficult time manipulating them, i.e. turning the bottom channel upside down to use as a top channel. Have disconnected from the ref. plane and use every tool
    in a futile attempt to turn the channel upside down.
    2002-09
    Madison, WI
    4,440
    Default Re: Metal Stud Wall
    You should be able to set the "cross sectional rotation" unless that's one of the families that adesk screwed up. I can't remember. I know we had to modify a bunch of their families to work correctly. Some we just had to add additional types for LLV vs LLH.
    Anyway, adjust the cross-sectional rotation to 90, go to a section view and use the align tool to set the elevation since you want the top of the channel and not the centroid.
    Hope this helps.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
  1. Light Gage Metal Stud
    By Thomas Maleski in forum Revit Structure - Families
    Last Post: 2010-11-29, 11:28 PM
  2. Metal stud DB rotate issue
    By beardking in forum Dynamic Blocks - Technical
    Last Post: 2010-06-08, 05:59 PM
  3. Metal stud at the end of the wall as well as repeat every 16"
    By spddesigns in forum Dynamic Blocks - Technical
    Last Post: 2007-05-24, 02:59 PM
  4. 6" Metal Stud Wall @ 16" o.c.
    By aokane in forum Revit Structure - General
    Last Post: 2006-03-08, 03:21 PM
