Thread: PIPE REDUCER IS NOT WORKING
    2007-09
    2
    Default PIPE REDUCER IS NOT WORKING
    Dear all,
    My name Amit Verma & I'm a user of Revit MEP by almost 3 years, now I'm using Revit MEP 2012, But it heppen first time with me if i try to use reducer it will not work see the image.
    please help me how to come out from this.
    2015-11
    Saint Louis, MO
    485
    Default Re: PIPE REDUCER IS NOT WORKING
    check your Revit.ini file, and make sure your path is correct to the lookup table for the reducer family. i don't remember the location, but you can search for other posts about it in this forum. does this family work in other projects, or on a different computer on the same network?
  1. Reducer for welded pipe
    By Martin Figlarz in forum Revit MEP - Families
    Last Post: 2014-07-26, 04:43 AM
  2. 2012: Nibco Pipe Fittings Not Working
    By Draft Punk in forum Revit MEP - Families
    Last Post: 2012-06-18, 03:50 PM
  3. Split Pipe not working in MEP '11
    By buhrito in forum Revit MEP - General
    Last Post: 2011-05-06, 07:26 PM
  4. Pipe Modify command not working
    By clark.fillinger in forum AMEP General
    Last Post: 2010-07-07, 01:45 AM
  5. Pipe hiding not working. in ABS2007
    By claus in forum Display Management
    Last Post: 2007-02-12, 06:26 PM
