I work with contour map. Usually in a project we need to do many drawings of different scales with these contours so we do xref. My problem is what to do with the labels. As you may know depending of the scale the text height need to be adjusted according to the viewport scale so the first question that comes to me is if it’s possible to do something with annotation that could do it ?
The xref map could contains the contours and the labels and depending of the viewport scale all the text labels would be scale just by adjusting the annotative scale keeping each label at their initial insertion point.
If someone can explain to me the procedure or if instead another solution could be done, I would appreciate.
