I've run into a snag with design options on a shared site. I did some searching and found this thread from 2005:
http://forums.augi.com/showthread.ph...s-from-1-model
The end result was essentially, "sorry, no. but that's a good wishlist item". I'm hoping somebody has made progress since then
In a nutshell, I have a building model with two design options linked into a site model. I would like to select one of those links and show it as Option 2. At the moment I don't think that is possible since the visibility graphics override affects ALL instances of the link.
I have attached an image of my project, where the issue is largely to do with the orientation of solar panels. The areas circled in red are where the panels show up under Option 2. At this point my best option is to tab-through and hide the panels on the second building and add in panels on top of the linked roof within the site model. It's not a great solution but it works.
Has anyone come across a better method? I'm looking at you, residential developers. It seems like this kind of functionality would be extremely helpful in placing multiple homes with different selected options across a suburban site.
Any thoughts would be appreciated.
-LP
