Thread: Changing Fonts in ProCAD
    Default Changing Fonts in ProCAD
    Hello i am currently using AutoCAD 2011 and ProCAD 2011. My issue is my company wishes to standardize all our text fonts accross all platforms(changing the style is the easy part i know how to do that) The issue is when i change font all my instrument balloon tags on existing drawings are no longer center justified. If i manually double click on every text in each balloon it refixes it self to be center. Like the justification is still set for center its just not centered Is there a global command that i can do that can update all blocks to regen back to center (note block edit does not work the justification is still centered its just simply off centered)
    I hope i made sense
    0,0,0 The Origin
    8,570
    Default Re: Changing Fonts in ProCAD
    I suppose expecting a REGEN to fix it would be too simple?
    Cairo - no, not Illinois
    5,069
    presuming that you are talking about blocks and attributes - have you tried the ATTSYNC command?
    Sweet the Attsync works perfectly Thanks alot
    Yeah thats going to make things alot more easier now
  1. Procad
    By djahnke.229446 in forum Software
    Last Post: 2012-05-10, 10:17 PM
  2. Autocad/Procad Font
    By djahnke in forum AutoCAD General
    Last Post: 2008-08-18, 09:58 PM
  3. Different fonts have started showing up as default AutoCAD fonts
    By jackie.112886 in forum AutoCAD General
    Last Post: 2006-05-15, 11:02 PM
  4. DWF loses protected fonts - download fonts option?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-03-25, 12:01 AM
  5. shx fonts to true type fonts
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-03-31, 02:53 PM
