Thread: Autolisp Code To Print Multiple Paperspace layout
    2012-04
    Default Autolisp Code To Print Multiple Paperspace layout
    Hi,
    I need autolisp code that allows me to print multiple(entire) paperspace layout of a drawing at one time rather using the shift/ctrl option and print. I would appreciate if someone help me with the code.
    Thanks in advance.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Autolisp Code To Print Multiple Paperspace layout
    Have you tried looking at the Publish command? If so, what about it does not work for you?
    You could use the (layoutlist) function to get a list of layouts. From there, you could use a foreach loop and print them out using a command sequence. To find out the correct key strokes for the command line version of plot, prefix the plot command with a hyphen (i.e.: -plot).
    9,805
    No lisp needed, just use Publish, or better yet publish from Sheet Set Manager, which does it with even fewer clicks.
    If you must use lisp for some reason, Opie has it covered.
  1. AutoLISP Help - Code not working on all machines
    By asleafty927995 in forum AutoLISP
    Last Post: 2015-01-06, 02:35 PM
  2. VB.Net - Print Paperspace to PDF
    By hrobert445725 in forum Dot Net API
    Last Post: 2013-12-04, 02:48 AM
  3. Help interpreting autolisp code
    By ae1329 in forum AutoLISP
    Last Post: 2012-09-15, 05:21 PM
  4. Text will not print or view in paperspace
    By stephen.coff in forum AutoCAD Annotation
    Last Post: 2007-09-05, 01:30 PM
  5. Replies: 13
    Last Post: 2004-07-29, 11:38 PM
