Thread: labels versus tags. can't switch back?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default labels versus tags. can't switch back?
    I have an alignment with spiral-curve-spiral transitions. I started with labeling the spirals and curves with their geometric information in a label pointing to each segment. Then the engineer decided he wanted a curve table instead. I think I managed to set that up. My labels disappeared and I put tags on the curves. Now we want to swtich back. I don't know how to do make it work so that when I pick a curve, I get a label, instead of another tag. Please help!
    Arizona
    2,478
    Default Re: labels versus tags. can't switch back?
    You may have to label the geometry twice, once with an Alignment Label/ Then with a Generla Line Segment Label
    Or Copy the alignment and place Tag Labels on one, and Normal Labels on the Copy.
    Arizona
    2,478
    Also, what I just tried could work for you...
    Before you ade the Label Tag to the Table
    Copy the contents of the Label;
    <[Tangent Direction(Udeg|FDMSdSp|P6|RN|DSn|CU|OF|AP|MB)]>
    <[Length(Um|P3|RN|AP|GC|UN|Sn|OF)]>
    Then Add the Tag to the Table
    Then Edit the Label Text; L1
    and Insert the value you just copied....
    1,324
    I did find the problem. It was the switch in the style editor.
    Arizona
    2,478
    The default display mode (Label/Tag) on the General Tab of the Style editor,right?
    Just filling in the details should others have this issue.
  1. Way to switch back to Home tab?
    By kristy in forum AutoCAD General
    Last Post: 2016-08-16, 05:01 PM
  2. 2013: Custom Elevation Tags and Project Versus True North
    By greyghost1984 in forum Revit Architecture - General
    Last Post: 2013-01-14, 06:42 PM
  3. how to switch back from MEP to Autocad
    By LynNV in forum AMEP General
    Last Post: 2010-09-15, 11:41 PM
  4. How to switch from Xref back to Previous Drawing!
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2008-11-25, 01:06 PM
  5. Editable Finish Tags Versus Schedules
    By gemmanuel in forum Revit Architecture - Families
    Last Post: 2006-06-06, 11:24 PM
