Thread: AIA standards plot style table for Revit to AutoCAD export
    2012-01
    59
    Default AIA standards plot style table for Revit to AutoCAD export
    Does anyone have the AIA standard pen assignments file or know where I can get it? For some reason it's not on my computer and I can't seem to find it anywhere on the Internet. I believe it is a .ctb file..
    The reason I am wanting it, in case anyone is familiar with the process, is so that after I export DWG files from my Revit model using AIA standards, I can then print the AutoCAD document using the AIA standards pen assignments thereby save me a lot of work in switching layers and line weights.
    Thanks in advance,
    in the upper right corner
    3,507
    Default Re: AIA standards plot style table for Revit to AutoCAD export
    Quote Originally Posted by skyeg3206316 View Post
    Thanks in advance,
    I would imagine that the NCS 3.1 or 4.0 ctb file would work?
    These are based on or from the AIA standards.
    3.1 uses colors based on NCS 3.1 layer color table
    4.0 uses object/layer line weights (not color) which is probably what you want?
    Hope it helps
    2012-01
    59
    Thanks a lot, the 4.0 file works perfect, so happy I found this
  1. CUI compatibility among Autocad versions, Plot Style Table
    By ruthellenwilliams in forum AutoCAD CUI Menus
    Last Post: 2014-03-25, 02:00 PM
  2. Replies: 1
    Last Post: 2006-10-13, 04:58 PM
  3. Export / Print the contents of a Plot Style Table (CTB or STB)
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2005-04-02, 05:28 PM
  4. Plot style Table
    By rputhenv in forum AutoCAD Plotting
    Last Post: 2005-03-05, 08:30 AM
