Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 58
Thread: Revit 2013 upgrade yet? - softaware stability, crashes & bugs
  1. #31
    2011-06
    101
    Default Re: Revit 2013 upgrade yet? - softaware stability, crashes & bugs
    I'm having trouble with ceilings duplicating every time lights are added. I posted about it here:
    http://forums.augi.com/showthread.ph...78#post1176278
    Since that post, it's become a real nuisance in that when I try to do an interior rendering, the ceiling-based lights don't light anything! My suspicion is that the extraneous ceilings are blocking the lights: as if each light cuts through its own ceiling-host and doesn't allow any other lights to cut through. I have to use studio lights.
    I didn't experience this issue in Revit 2012. Has anyone else had this problem? Is there a non-studio light work-around?
  2. #32
    2011-06
    101
    Also, I just downloaded and installed an update for Revit 2013, and now my cloud-rendering capability has gone all askew. Before the update, I set my Render Quality, Image Size, Exposure, etc. once, and it preserved those settings each time I rendered thereafter (at least for the time I was in the file). Now, I need to reset the settings each time I click "Render in Cloud".
    Another thing is that the renderings seem to appear at random in the Render Gallery. At first, they showed up at the beginning of the thumbnails, but now they can appear third or fourth in line. It's not terrible, but it is a little annoying to have to hunt for each new rendering.
    Also, the Exposure setting seems to have gotten a little wonky: Even if I have it set to "Advanced," it frequently doesn't pick up my interior lights unless I set the lighting to "Interior" in my native render dialog. This happens only about 50% of the time, so I'm having trouble nailing down the cause. It's a bit maddening.
  3. #33
    2009-03
    Somerville, MA
    1,060
    I know this thread is a little out of date, but I keep seeing little bugs here and there for 2013. Did the first service release fix most of the bugs? Is 2013 stable? Is it a very, very, very safe time to upgrade?
  4. #34
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Wow, Damo. You have great timing when reviving an old thread:
    http://www.revitforum.org/architectu...html#post69261
  5. #35
    2002-09
    Madison, WI
    5,687
    Umm stable isn't the word I would use. But I guess I'd say I've had more crashes with this version than the previous. IMHO it's not one of the better ones. There's still lots of bugs, things that end up missing from sheets, the wysiwyg idea isn't there. It's usually what you see is what you get, but not always. The service pack did address a few issues, butt there's still lots of underlying ones. But I wouldn't expect to see any fix for those until 2014 is out. Just my 2 cents.
  6. #36
    2009-03
    Somerville, MA
    1,060
    Thanks, looks like we'll keep waiting!
  7. #37
    2002-09
    Madison, WI
    5,687
    Your only issue with keeping on waiting, is that you'll have to convert it to 2013 at some point. At this point in time, I don't expect to see another service pack for 2013, but I could be wrong. It's not the worst ever, but I know my co-worker (working on a similar set-up) crashed out 3 times already today.
  8. #38
    2009-03
    Somerville, MA
    1,060
    Quote Originally Posted by david_peterson View Post
    Worst case scenario: couldn't we just skip it and go straight to 2014?
  9. #39
    2002-09
    Madison, WI
    5,687
    That's an option, but not one I would suggest. When they create new releases and add new features, one of the things they do is convert the content of existing models to work with their new line of programming. If you skip a version, that upgrade may not happen. Best case, no problems, everything works and your model remains 100% intact. Worst case, well..... I leave that up to your imagination. My suggestion would be to wait as long as you and your consultants are willing. Then detach the model and test an upgrade to 2013 and see what happens. If you really want to wait for 2014, fine, but I'd still open and save it in 2013 first. That's the suggested method and the one recommended by adesk.
  10. #40
    2009-03
    Somerville, MA
    1,060
    Fair enough! I'll definitely keep that in mind when I recommend to our IT and staff when to upgrade. Thanks.
  1. 2014: Revit 2013 Crashes on startup- without any error.
    By fstmaxs370636 in forum Revit Architecture - General
    Last Post: 2013-04-12, 09:27 AM
  2. 2013: Revit 2013 Crashes opening a view
    By bmyrum in forum Revit Architecture - General
    Last Post: 2013-04-03, 01:15 PM
  3. Revit 2012 to 2013 upgrade consequences...
    By apitcher799568 in forum NavisWorks - General
    Last Post: 2012-06-20, 12:46 AM
  4. upgrade to 8.1 crashes
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2005-09-28, 03:44 PM
  5. Crashes after Upgrade.
    By Paul Monsef in forum Revit Architecture - General
    Last Post: 2004-01-26, 08:45 PM
Tags for this Thread
