One thing I LIKE about 2013 is the fact that you can undo accidental pan-changes to camera views. If I accidentally rotated a camera view in 2012, I had to sit there and putz around until I got it back to looking the way that it should.
Don't forget about the Rewind function on the steering wheel. Might save accidentally undoing something other than view changes.
It would be SO SWEET if you could have a Keyboard Shortcut for Rewind!
Huh. Doesn't look like it's possible to set up in keyboard shortcuts. Bummer.
I am having this problem with 2013 that it locks up and gives me the spinning wheel when i do a save as command or sometimes try to open our network location for loading families. It also freezes trying to save some PDFs to our network.
Sounds like a system or network issue, rather than Revit.
We are using update release 2, and are finding it generally very stable; though it has a graphics glitch sometimes when opening up views, whereby the screen flickers between two images of the view overlaid on top of each other.
