Thread: Turning a "Not for construction" text on and off?
    2010-12
    74
    Default Turning a "Not for construction" text on and off?
    At a past employer, I thought that I had learned of a way to create a text or label and then using some type of parameter setting, be able to add a check box in the properties bar which would allow that text or label to be turned on or off. I want to have a "Not For Construction" text on my title block and have the option to click it on or off.
    It's been too long since I was at that employer and have forgotten how to do it. I've attempted to follow instructions using shared parameters, but that doesn't seem to be exactly what I'm trying to do.
    Any suggestions?
    Thanks.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Turning a "Not for construction" text on and off?
    You make the shared parameter, add it to both your tblk and project, then select the text in the tblk and add a visibility parameter by clicking the little button to the right of the Visible Check box in the properties box that is visible when you select the text(label) in the tblk family. You don't need the shared parameter at all, if you just want it to say the same thing all the time and just turn on and off, then you just add the visibility paramete..
    Scott D. Brown, AIA
    BECK
    2010-12
    74
    Thanks! I remembered that it was much simpler than using the shared parameters - the visibility parameter was all that I needed since I just wanted it to say the same thing only have the option of being on or off.
  1. Replies: 0
  2. if filter text equals "*" insert block "*"
    By d_m_hopper in forum AutoLISP
    Last Post: 2009-04-24, 05:46 PM
  3. Turning off the Startup "Recent files" screen
    By Norton_cad in forum Revit - Platform
    Last Post: 2009-03-18, 06:17 AM
  4. How to show "last printed" or "path" text in layout
    By cstone in forum AutoCAD General
    Last Post: 2008-11-29, 12:05 AM
  5. Turning a "create in place" component into a famil
    By Amy_Bloss in forum Revit Architecture - Families
    Last Post: 2004-03-20, 11:27 PM
