Thread: LISP not grabbing annotative text size properly
    2007-01
    33
    Default LISP not grabbing annotative text size properly
    I am having an issue with an old LISP routine. I am Attempting to convert it over so that is will use the annotation scale to set the size of the text but I cant seem to get it to show up at the right size. Id like it to show up at 3/32" in paper space on any annotation scale size. I have attached to offending routine. If anyone could help me it would be wonderful!
    2007-07
    Jo'burg SA
    4,344
    Default Re: LISP not grabbing annotative text size properly
    Look at a post I did a while back: http://www.cadtutor.net/forum/showth...tocad-drawing&
    #14 an #16
  1. Rotating annotative text with LISP
    By amaser in forum AutoLISP
    Last Post: 2009-07-15, 08:42 PM
  2. Grabbing The Text From another Window
    By marutivinod.p in forum Dot Net API
    Last Post: 2009-06-25, 11:42 AM
  3. Revit does not size text properly?!
    By brede.207016 in forum Revit Architecture - General
    Last Post: 2009-01-29, 10:02 PM
  4. CRASH, RECOVER, ANNOTATIVE DIM TEXT SIZE
    By dbrownson in forum AMEP General
    Last Post: 2008-06-27, 05:15 PM
  5. Annotative Text Resets to size 0"
    By mzabritski in forum AutoCAD Annotation
    Last Post: 2007-12-05, 05:03 PM
