Thread: If statement
    2011-03
    Kansas, US
    5
    Default If statement
    I am having problems with if statement in my routine. I want to simply want the user to choose
    if they wnt to create a new folder or not. The routine works but the response I is not what I want. It is
    suppose to say ""Folder Does Not Exists! Do You Want to Create a New Folder?" if the folder was not found.
    Or, ""Folder Aready Exists!" if it does find the folder. Instead it gives me both messages one after the other.
    What am I doing wrong?
     (defun C:MkFoldr (\Foldr1 JobNo FoldrName PathName ChkFoldr)
        (setq Foldr1
        (dos_getdir
          "Create new CAD Library Folder"
          "J:\\WMSP\\"
          "Select destination for the folder"
        (dos_chdir Foldr1)
        (setq JobNo
        (dos_editbox "Editor" "Enter Job Number" "XXXXX")
        (setq FoldrName (strcat JobNo "-CAD Library"))
        (setq PathName (strcat Foldr1 FoldrName))
        (setq Chkfoldr
        (dos_dirp PathName)
        )        ;;this work ok to this point
        (if (= chkfoldr nil)
          (progn
     (setq yes
            (dos_msgbox
       "CAD Library Folder"
       4
     (if (= yes 6)
       (dos_mkdir PathName)
          (progn
     (setq yes
            (dos_msgbox
    2008-02
    Toronto, On
    59
    Default Re: If statement
    There was a parenthesis mis-match in (if (= chkfoldr nil)...
    Try the following:
      (setq Foldr1
    	 (dos_getdir
    	   "J:\\WMSP\\"
    	);end setq
      (dos_chdir Foldr1)
      (setq JobNo
    	);end setq
      (setq Chkfoldr
    	 (dos_dirp PathName)
        (progn
          (setq yes
    	     (dos_msgbox
    	       4
    	       );end dos_msgbox
    	    );end setq
          (if (= yes 6)
    	);end if
          );end progn
        (progn
          (setq yes
    	     (dos_msgbox
    	       );end dos_msgbox
    	    );end setq
          );end progn
        );end if
      );end defun
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    First line might be like this:
    (defun C:MkFoldr ( /  Foldr1 JobNo FoldrName PathName ChkFoldr)
    bad copy-paste reason i think
    Regards,
    ~'J'~
  1. If statement help
    By prose in forum AutoLISP
    Last Post: 2010-01-06, 05:35 PM
  2. WHILE Statement...
    By BeKirra in forum AutoLISP
    Last Post: 2009-03-26, 02:57 PM
  3. Bad if statement?
    By clog boy in forum Revit Architecture - Families
    Last Post: 2009-01-15, 12:48 PM
  4. Need help with an If else then Statement
    Last Post: 2008-11-14, 04:04 PM
  5. Help with IF statement
    By kelly.195705 in forum AutoLISP
    Last Post: 2008-10-02, 05:47 PM
