Thread: Raised floor construction (and what might be called laziness)
    2008-07
    55
    Default Raised floor construction (and what might be called laziness)
    Hello again all.
    I'm working on a project using raised floors (150mm above a 200mm deep structural slab). Floors, curtainwall, etc are based upon a conceptual mass.
    I was lazy/working quickly at first and defined the ENTIRE floor (concrete, void, finish) in one assembly.
    My hope, when cutting sections, was for the floor to be 'smart' enough to show the assembly as above. Instead the whole assembly appears as concrete.
    Is it possible to define this better within one assembly... or is the 'best' practice to go back and re-define the raised floor as a separate floor (and on a different workset)?
    Thanks.
    JP-
    And, for reference, this was probably the closest post I found: http://forums.augi.com/showthread.ph...floor-finishes
    2008-07
    55
    Default Re: Raised floor construction (and what might be called laziness)
    Oh, never-mind.
    My detail level was simply far too coarse (duh).
    But I should still consider splitting out to individual worksets.
    (Gotta make stupid mistakes sometimes)
    JP-
  1. hatching construction elements under the floor
    By jkk007 in forum Revit Structure - Wish List
    Last Post: 2007-11-06, 08:02 AM
  2. Raised Paneling Wainscoting
    By Anthony.d in forum Revit Architecture - General
    Last Post: 2007-05-25, 12:10 PM
  3. Architectural - Raised Panel Block
    By Father-of-Ten in forum Dynamic Blocks - Sharing
    Last Post: 2007-02-02, 04:59 PM
  4. raised paneling
    By tect75 in forum Revit Architecture - General
    Last Post: 2005-10-14, 04:17 PM
  5. Cabinets with Raised Panel Doors
    By doug.61606 in forum Revit Architecture - Families
    Last Post: 2004-09-16, 02:16 PM
