Thread: SDI Command at the promt
    2003-11
    4
    Default SDI Command at the promt
    When selecting DWG files using Windows Explorer, each selection opens a new AutoCad application. The cure for this is to alter the SDI value at the Command line from <1> to <0>.
    Can anyone give me a little more info on what the SDI setting controls/adjusts.
    Ceejay
    Cairo - no, not Illinois
    5,069
    Default Re: SDI Command at the promt
    Single Document Interface. When set to 1, only 1 drawing can be open in a sessions. turning OFF SDI, by setting to zero, enables Acad to run in MDI, Multiple document Interface. It's basically a legacy setting, dating back to DOS days. I am suprised that your LT defaults to 1, since the whole point of that was to support older/not updated add-ons and customization.
    2003-11
    4
    Many thanks - one of the guys has had a new computer and the subsequent re-install of AutoCad for some reason set this default position to <1>.
    Ceejay
  1. promt for text to append to layer
    By lisaj98052674917 in forum AutoLISP
    Last Post: 2014-06-24, 10:49 AM
  2. Replies: 0
    Last Post: 2011-09-23, 07:21 PM
  3. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
  4. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
  5. Replies: 8
    Last Post: 2005-06-30, 02:32 PM
