Thread: Tag Orientation
    2001-12
    37
    Default Tag Orientation
    In the attached pdf file you will see where I have tagged the beam at Grid 1 (24x36) and Grid 2 (15x36) then at Grid 3 the Tag is vertical (not horizontal).
    I selected the tag and see the Property option for horizontal or vertical, but the tag doesn't change orientation.
    What could be causing this problem?
    2001-12
    37
    Default Re: Tag Orientation
    I see that so far there isn't any answer to the problem except the simple one.
    I deleted the beams added new ones and the tags are horizontal.
    2001-12
    37
    OK I am slow. I didn't really solve the problem.
    I discovered that the new beams I placed were not sloped.
    When I sloped the Beams the tag rotated to vertical.
    Is there some way around this problem?
  1. 2012: UCS Orientation
    By cjshaw in forum AutoCAD LT - General
    Last Post: 2013-06-19, 03:00 PM
  2. Schedules Orientation
    By wags5116 in forum Revit MEP - General
    Last Post: 2011-09-14, 01:39 PM
  3. Schedule Orientation
    By mylogs in forum Revit Architecture - General
    Last Post: 2011-06-24, 10:26 PM
  4. UCS Orientation
    By dan.spinella in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-04-23, 02:51 PM
  5. dim orientation?
    By smdin79 in forum AutoCAD LT - General
    Last Post: 2005-04-19, 03:34 PM
