Could anyone tell how to insert a diameter symbol to notepad?
Thanks for your help.
This ... ?
Code:(if (setq f (getfiled "Name of file" (getvar 'dwgprefix) "txt" 1)) (progn (setq f (open f "w")) (write-line "%%c" f) (close f) ) (princ) )
Tharwat, I don't think that does what you think it does. Notepad does not interpret the AutoCAD characters the same way.
Bokirra, you might look into this link to get a better understanding of the necessary characters.
(write-line "Ø" f)
ALT+0216 <------
For other characters you could try the standard windows program Character Map (under Start-->All Programs-->Accessories-->System Tools-->Character Map). Then it displays all the characters per font, if you click on any of those characters a description and keystroke is displayed in the status bar. Or you could click the Select button and then Copy - then you can paste the character in any program. Note, not all characters are available in all fonts.
Thanks, irneb.
I don't really like to use the character map as it takes time.
As I understood in writing of Autolisp we normally don't use many special symbols.
I think pbejse's tip may work for me.
Only one thing is I need to have a list sticking on the wall.
Ø - ALT+0216
degree - ALT+????
Does anyone know where to get an entire list?
Thanks to everyone's input.
ALT+248
Here:
http://tools.oratory.com/altcodes.html
You can generate most of the ANSI/ASCII codes direct in lisp using the chr function. Just place it in a loop with a number incremented from 32(space) up to 255 (below 32 are control codes line new-line / tab / etc). For those other characters, you could use one of three methods: http://www.fileformat.info/tip/micro...er_unicode.htm
I.e.:
- Alt and the numpad +, then type the hex code for the UniCode character
- Alt and then numpad 0 and the decimal code for the unicode character
- Alt and then the decimal code for your current codepage
BTW, you can enter the same idea in ACad's text.
For a full listing of all unicode characters: http://www.utf8-chartable.de/
Just remember that not all characters are defined in all fonts, you might end up getting a ? instead of the character you wanted. At least if you use the CharMap it only shows those characters defined inside the font you specify.
I have a list of the most common charactors on my home page:
http://home.comcast.net/~721rr/
and a link on it with a page with a lot more charactors:
http://home.comcast.net/~721rr/Charactors.htm
The more common ones I can usually remember now.
Tom Beauford P.S.M. - Civil 2013 on Windows 7 Pro
Design Analysis - Leon County Public Works/Engineering
Ph# (850)606-1516
Thanks for everyone's help.
I will take the list sugguested by pbejse.
And thanks to irneb for your reminder.
Just remember that not all characters are defined in all fonts, you might end up getting a ? instead of the character you wanted...
