Thread: Countertop family not working right in upgraded file
    2004-06
    Memphis TN area
    6,700
    Default Countertop family not working right in upgraded file
    I edited the U-shaped Countertop family a few months back so that the instance grip arrows show up at each end of the countertop instead of in the middle. I did this by placing the instance parameter dimensions on the end of the actual geometry instead of to ref planes. When I load this into a new, blank project, it works fine. However when I load it into a current project that was upgraded from a 2005 project (new phase), the grips at the ends of the countertop don't show up.
    Any ideas why this might happen?
    Intern Architect, BIM Manager/Coordinator
    AERC, PLLC
    Hernando, Mississippi
    Revit - all up in your voxel space
    Active Member ttiefenbach's Avatar
    2009-03
    Orlando, Florida
    71
    Default Re: Countertop family not working right in upgraded file
    I'd make it a rule to never dimension directly to geometry. This can lead to issues with parametrics. You've probably lost those grips because you don't have any weak or strong references and so it doesn't display the grips for them. Steve Stafford wrote a good post about how to move those grips to the center of the geometry by utilizing Reference Lines instead of Reference Planes. Check it out: http://revitoped.blogspot.com/2012/0...planes-vs.html
    Anthony Tiefenbach, BIM Manager
    HuntonBrady Architects
    Revit Architecture 2013 Certified Professional
  1. 2012: upgraded 2011 file, can't open parent plan
    By patricks in forum Revit MEP - General
    Last Post: 2011-08-25, 01:10 AM
  2. Kitchen Countertop Family
    By jamesanderson in forum Revit Architecture - Families
    Last Post: 2009-02-03, 01:50 PM
  3. Family Shifts when upgraded to 2009
    By NKramer in forum Revit Architecture - Families
    Last Post: 2008-06-24, 05:10 PM
  4. Editing upgraded Family Files in Revit 9.1
    By rgranja508683 in forum Revit Architecture - Families
    Last Post: 2006-10-03, 03:41 PM
  5. Plan regions and revit 9 upgraded file
    By Wesley in forum Revit Architecture - General
    Last Post: 2006-05-05, 09:20 AM
