Thread: AutoCAD to Revit Family Material Issue
    2012-03
    5
    Exclamation AutoCAD to Revit Family Material Issue
    I have searched this issue on this forum and have found helpful tips but nothing seem to be working for me.
    I had a 3ds Max file, exported it as a .dwg and opened it in CAD. Within CAD, I exploded the geometry and placed each component onto a seperate layer and saved the file. I then opened Revit, create new family, generic mass, and imported my file. I checked my imported object diaglog and the layers are there for the object and the render materialxxxxxxxxxx. I have changed the render material and nothing will change in the file when it is in realistic view or rendered.
    I read on one of these forums to create an entourage family instead of generic mass. I tried this. Once I created the entourage family, I was able to change the materials on some of the objects but not on everything. What the heck is going on? I have a ton of families that I NEEEED to be able to change the materials on. What can I do?
    I have attached both the generic mass family and the entourage family for reference.
    Thank you in advance for any help. I need to be able to create these families within the next 48 hours to keep on track for my thesis project.
    THANK YOU!!
    2012-03
    5
    Default Re: AutoCAD to Revit Family Material Issue
    Here is the CAD file. I tried saving it as a mesh file also and when I import it into revit, there is an error and it shuts down. small clothing rack on ground.DWG
  1. apply material to imported DWG in Revit family
    By diesellam in forum Revit Architecture - General
    Last Post: 2018-09-18, 07:31 PM
  2. Window Family plan display issue - Revit 2012
    By acampusano673336 in forum Revit Architecture - Families
    Last Post: 2012-10-25, 10:18 AM
  3. Flow - Is this a Family, Connector or Revit Issue??? (Revit MEP 2011)
    By David-Allan in forum Revit MEP - General
    Last Post: 2011-01-31, 07:40 AM
  4. AutoCAD / Revit series network license issue
    By tim.101799 in forum AutoCAD General
    Last Post: 2010-10-15, 03:34 PM
  5. A material issue ?
    By file_transfer101 in forum Revit Architecture - General
    Last Post: 2010-04-19, 06:41 PM
