Results 1 to 9 of 9
Thread: Anyone know how to replicate this light?
    2012-03
    5
    Default Anyone know how to replicate this light?
    Here is this light that I would love to model. I've tried modeling it as a in place generic mass but it doesn't seem to be working correctly. Any suggestions? Any examples similar to this one? I haven't been able to find one.
    2003-08
    Vancouver, BC Canada
    3,390
    Default Re: Anyone know how to replicate this light?
    A mass object can not be a light fixture (at least one that emits light). You'll need to create a light fixture family.
    I can't tell if each of these 'rods' is a single fixture or if they are combined into a single fixture. Either way you'll need to use reference lines to allow the component to rotate in more than one plane.
    To create a fixture family with multiple light sources you'll need to model one of the 'rods' and then nest it a number of times into a light fixture family. Within the fixture family use reference lines arranged at the correct angles and then place the nested families on the various ref lines.
    If this is your first family, you've chosen a tough one
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    I could stop if I wanted to mthurnauer's Avatar
    2001-11
    Cincinnati, formerly Chicago
    388
    I can see that the same fixture in the background is hanging straight vertical and others are suspended from both ends. I think you will want to next the modeled fixture as demitri said. I can see one version nested into a end-supported pendant configuration and another where you can define the pendant length at both ends.
    2009-03
    Somerville, MA
    669
    The hard part is getting the "rod" fixture to nest so that it can be oriented along any angle in 3-dimensions, right? Wasn't there a long thread about this topic not so long ago? I tried this morning to create a family that could be nested and configured in all the ways show in the photo, but with no luck. I couldn't even get the light source to be locked to a ref line and rotate with it. I'd find this topic very interesting as a test case. Anybody know where to find that old thread?
    2002-09
    Madison, WI
    4,439
    Adaptive components maybe? Just thinking this looks like it may be a good candidate for it.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    2003-08
    3,390
    Damon,
    I think you are referring to this thread.
    http://forums.augi.com/showthread.ph...ht=rotate+axis
    The trick is to host nested families on the workplanes of the reference lines. As mentioned by mthurnauer this needs to be a single `rod`fixture that can be manipulated on three axes.
    BIMblog.ca
    AUGI Addict cdatechguy's Avatar
    2004-02
    CdA, ID
    1,371
    Instead of creating a light with a light source....create a family that has a light enabled material...
    Michael "MP" Patrick
    "I never make stupid mistakes. Only very, very clever ones."
    2009-03
    Somerville, MA
    669
    Here's my attempt. It took three families as suggested by others. Michael, I took your advice and skipped the light source in favor of an emitting material. This one has the three rods and you can change their angle downward. I didn't hook up all the parameters for length and radius, etc. If anybody would improve this family, suggestions are more than welcome. mxchick, I hope this helps at least to get you started. If not, it was a good exercise.
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    986
    Quote Originally Posted by damon.sidel View Post
    .... Anybody know where to find that old thread?
    For your information, I have written a tutorial about multiple rotations. It can be found at:
    http://planta1.com/forum/entry.php?1...-by-parameters
    And, it was published in the Wikihelp as well, at:
    http://wikihelp.autodesk.com/Revit/e...Different_Axes
  1. Revit light fixture light source geometry won't go away
    By david_spehar in forum NavisWorks - General
    Last Post: 2012-02-21, 08:05 PM
  2. Pendant Light Fixtures and Light Sources
    By heiko.stugg in forum Revit MEP - Families
    Last Post: 2011-01-31, 11:25 AM
  3. Convert MEP Light to Ceiling Hosted Light
    By PaperStreet SoapCO in forum Revit Architecture - Families
    Last Post: 2009-11-25, 05:45 PM
  4. Replicate
    By xiqx in forum Revit - Platform
    Last Post: 2009-06-17, 01:40 PM
