Results 1 to 9 of 9
Thread: Retaining Wall Best Practice?
    2010-04
    53
    Default Retaining Wall Best Practice?
    So here is my problem with retaining walls.
    1) I need an assembly that can grade to the surface but has the option to override with profile of feature line.
    2) the face of the wall must show when visual style is set to "realistic"
    3) the backside of the wall must form a tidy surface for pasting into a datum surface whether in cut or fill condition
    4) the front and top of the wall must form a tidy surface for contour line generation
    5) must be able to cut engineering sections from the wall
    6) must have the basepoint of the wall centered so I can run it down an alignment of the centerline
    I cannot find a system that accomplished all this. I built an assembly with marked points for visualization, but no shapes for sections or I can use the wall subassembly but then I lose the visualization option and centerline option. I have never found a quick easy reliable way to create retaining wall with this software.
    2001-10
    Arizona
    2,337
    Default Re: Retaining Wall Best Practice?
    One can make this type of retaining wall quite readily from Generic Links....
    see some of the tutorials here for an understanding of procedures involved
    http://primeservicesglobal.com/tutorials.php
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2010-04
    53
    can you just post a finished assembly with the these properties so that I can download and study it
    2010-04
    53
    MyBestWallEver.dwg and here it mine
    2001-10
    Arizona
    2,337
    Quote Originally Posted by robert.248186 View Post
    I would rather you watch the video(s), as I answer most question you will have therein.
    Be your Best,
    Michael Farrell
    2010-04
    53
    I WISH I COULD BUT YOUTUBE IS BLOCKED IN CHINA. IT WOULD BE MUCH EASIER FOR ME TO EXAMINE THE ASSEMBLY AND SUBASSEMBLY CONFIGURATION AND REVERSE ENGINEER IT TO SUIT MY PROJECTS.
    2001-10
    Arizona
    2,337
    the video is not on you tube...please follow the link provided.
    http://primeservicesglobal.com/tutor...nericlinks.mp4
    Be your Best,
    Michael Farrell
    2010-04
    53
    I WOULD RATHER JUST DOWNLOAD AND EXPLORE THE ASSEMBLY. BTW, I ALREADY DISCOVERED THE ASSEMBLY I POSTED WILL ONLY WORK IN CUT CONDITION. IF IT SWITCHES TO FILL, THE DAYLIGHT AND DATUM SURFACES ARE INCORRECLY IN CUT. THIS CALLS FOR A CONDITIONAL SUBASSEMBLY UP THE HIERARCHY TO EVALUATE THE CONDITION OR I CAN RETURN TO S.A.C. AND TRY MY LUCK AGAIN
    2001-10
    Arizona
    2,337
    And I would rather that you learn the concepts explored in the video(s) so you will gain more valuable knowledge.
    Be your Best,
    Michael Farrell
  1. Retaining wall volumes
    By cadtag in forum AutoCAD Civil 3D - Sections
    Last Post: 2012-01-26, 10:27 PM
  2. Railings on Retaining Wall
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2009-03-18, 12:24 AM
  3. What's the best way to model a retaining wall?
    By Dave F. in forum Revit Structure - General
    Last Post: 2008-11-14, 05:44 PM
  4. Stepped retaining wall?
    Last Post: 2008-08-04, 01:09 PM
  5. Retaining wall on slope?
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2004-02-20, 07:12 PM
