Thread: Setting up tabs in ACAD MEP 2013 from BDS
    I could stop if I wanted to Liamnacuac's Avatar
    2005-12
    441
    Default Setting up tabs in ACAD MEP 2013 from BDS
    I installed ACAD 2013 from our Building Design Suite, and it looks like it installs both ACAD and ACAD MEP. I typically create custom menus through MEP and then vanilla ACAD. I used my 2012 menus, which is probably my problem, but I needed a place to start.
    I have the tabs and panels I want, but all of my AEC tools are non-functioning, whereas the MEP tools and my own tools work fine. It seems I need to add a path to the AEC tools, but I haven't a clue where to look. I installed in default locations in windows 7...
    Any help?
    2009-05
    32
    Default Re: Setting up tabs in ACAD MEP 2013 from BDS
    Try here: C:\Users\(your name)\AppData\Roaming\Autodesk\(your software version)\R19.1\enu\Support
    This is for 2012, the R19.1 will be different depending on which version you are looking for. You will need to load the cuix file for whichever version you need.
    2005-12
    441
    That worked. Merci!
  1. Acad 2013 Docking
    By TerribleTim in forum AutoCAD General
    Last Post: 2012-05-04, 03:41 PM
  2. Setting up each user with ther own ACAD.CUI
    By koconnor in forum CAD Management - General
    Last Post: 2008-12-03, 08:02 PM
  3. problem setting profiles via acad.lsp
    By tbuck in forum AutoCAD CUI Menus
    Last Post: 2008-11-18, 06:47 PM
  4. Problem Setting up Acad 2009 Trial Version
    By bennygo in forum AutoCAD General
    Last Post: 2008-10-17, 05:08 PM
  5. Save reminder - system setting or project setting?
    Last Post: 2005-07-08, 01:47 PM
