Thread: Dimension - Change Witness line style
    Member essochay's Avatar
    2008-02
    15
    Default Dimension - Change Witness line style
    is it possible to change the witness line style?
    Please see attached.
    the Red Dashed line is simply a detail line laid over the witness line.
    Can I change the actual witness lines to this line style?
    Dimension hopeful.pdf
    Chay Turner
    Architectural Intern
    Novus Architects
    Mount Pleasant, SC
    Active Member ttiefenbach's Avatar
    2009-03
    Orlando, Florida
    71
    Default Re: Dimension - Change Witness line style
    You can specify a different line style is it's the centerline of an element by changing the "Centerline Pattern" in the Type properties of the dimension style. Otherwise no.
    Anthony Tiefenbach, BIM Manager
    HuntonBrady Architects
    Revit Architecture 2013 Certified Professional
    2008-02
    15
    Bummer, thanks.
    Chay Turner
    Novus Architects
    Mount Pleasant, SC
  1. Dimension Text Moves After Editing a Witness Line
    By bskripac in forum Revit Architecture - General
    Last Post: 2008-12-01, 11:01 PM
  2. Unable to change Feature line, Line style
    By m.vanitallie in forum AutoCAD Civil 3D - Grading
    Last Post: 2008-03-20, 01:46 PM
  3. Witness line dimension out of view!
    By blumarble in forum Revit Architecture - General
    Last Post: 2006-05-09, 07:53 PM
