Thread: Is there a way to trim a vertical alignment at a vertical curve?
    Default Is there a way to trim a vertical alignment at a vertical curve?
    I have a roadway alignment that traverses over a bridge. The profile ties in nicely on either side of the bridge, with a vertical curve over the bridge.
    The client would like the roadway profile to tie into existing shortly after crossing the limits of the bridge. On paper, I can easily just trim the vertical curve, say 10 feet beyond the limits of the bridge, and then insert an angle point on each side of the bridge that allows vertical a tangent on each side to tie in shortly thereafter.
    Essentially you would have the existing grade, an angle point, a tangent, an angle point at the PVC, the vertical curve, an angle point at the PVT, a tangent, an angle point, and the existing grade. Above the vertical curve would be the PVI for the crest curve.
    The vertical curve would likely be asymmetrical after being altered, but the original design of the curve is symmetrical. Also, if possible, I would like to retain definition of the original symmetrical vertical curve, to allow future roadway work to tie in smoothly.
    Is there a way to accomplish this using Civil3D? I was able to do this sort of thing using LDD without any issues.
    Thank you to whoever can help shed some light on this.
    2001-10
    Arizona
    2,337
    Default Re: Is there a way to trim a vertical alignment at a vertical curve?
    You may need to resort to this sort of trickery...
    The actual profile will be set to not display....
    Then fictional profile segments created to show up on the plans...
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    Thanks Michael.
  1. Which Vertical Curve?
    By jacunningham in forum AutoCAD Civil 3D - General
    Last Post: 2012-01-05, 01:27 PM
  2. Vertical Curve Label Styles
    By mooker16 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-11-23, 05:08 AM
  3. Vertical Curve Labels
    By mooker16 in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-11-19, 01:32 PM
  4. Vertical curve labels
    By dfarris75 in forum Land Desktop - General
    Last Post: 2006-10-26, 06:58 PM
  5. Vertical Alignment LDD R2
    By jsauler in forum Land Desktop - General
    Last Post: 2004-10-08, 02:14 PM
