Results 1 to 10 of 19
Thread: How can I divide this curve line evenly?
    2007-09
    83
    Default How can I divide this curve line evenly?
    I got a surface like this,it contains 3 arc which connected one by one, and then , how to divide it evenly,just like the 3rd image that created from a spline?
    Thanks a lot!!
    crazy, can't upload the image
    2001-11
    Cincinnati, formerly Chicago
    400
    Default Re: How can I divide this curve line evenly?
    what version are you in? IN 2013 (I am not using yet, but read the literature about it) there is a feature that distributes points evenly along a curve. Now without 2013, if you place a point on a path, I think there is a parameter that indicates its distance from the end of the host. so, you could add up the total length of all three curves, divide it by the # of divisions you want, place points, and then enter in the distance from end for each point.
    2007-09
    83
    Quote Originally Posted by mthurnauer View Post
    thanks, follow your words I find the parameters in the properties panel,that's really a way to work it out,yes!
    2015-12
    Orlando, FL
    1,049
    Can you try to post the image again?
    2007-09
    83
    I tried it again, and failed then in the "Manage Attachments " page. The whole problem is, how to make Revit to take the line (3 arc connected one bye one or so) as a single Spline? So that I can place the mullion evenly. If not , Revit place mullion at 3 different pace on each arc, and 2 mullion at the joint. I am not sure if this make it clear. thanks
    2010-04
    Toronto
    42
    Assuming your Facade will be segmented into straight segments (unless you want curved glass then it gets tricky and fun) all you have to do is use spline through points. place the points on the arcs where you want your mullions (so the mullions always fall on your arc set out) the actual surface you create will not be 100% following your initial surface but the points that matter will. you can now divide this surface evenly allowing easy placement of your Panels (assuming you are using pattern based panels)
    2007-09
    83
    I tried this way just now,the key point is that ,the new spline shape doesn't keep with the original arc accurately, just like you mentioned . But sure, this is a way, thanks
    2009-09
    245
    The easiest way i was able to do this is draw the curved curtain wall, place your mullions somewhat randomly. Place a Radial dimension of the arc. Add in grid lines radiating from the radius, dimension the grid lines with the angular dimension style and hit "EQ." They will equal out.
    2007-09
    83
    Quote Originally Posted by kmarquis View Post
    nice idea,when I have only one arc shape. And when there are 3 arc which follow one by one, perhaps , there will be 2 mullions in the joints. OK, delete one of them
    2015-12
    Orlando, FL
    1,049
    Quote Originally Posted by mike99 View Post
    So, does that solve the question? Unfortunately, you could not post an image, to understand better what you needed to do. I don't understand why you could not post an image. Do you want a polygonal plan or a curved one?
  1. Replies: 1
    Last Post: 2014-11-26, 11:22 AM
  2. 2014: Evenly spacing words along a line. Not letters.
    By ross.gallagher in forum AutoCAD Civil 3D - General
    Last Post: 2013-12-11, 03:42 AM
  3. 2014: Line and Curve labels do not print right
    By mhildenbrand in forum AutoCAD Civil 3D - General
    Last Post: 2013-11-06, 03:03 AM
  4. Divide a line in 3'-0" increments
    By BCrouse in forum AutoLISP
    Last Post: 2005-12-14, 06:16 PM
