Results 1 to 10 of 11
Thread: Scale Issues
    2010-06
    41
    Unhappy Scale Issues
    Can anyone give me some help please?
    I have a drawing from our customer (I think created in autocad 2010) In model space the drawing is drawn at 1:1 as I would expect. The text heights are what I would expect to see in papaerspace at a scale of 1:100 ie 4.0, 2.5 etc. I have checked to see if the text styles are annotative & as far as I can see they are not. Also when I go to paperspace to set the viewport scale to get a reasonable view I need to set it at 1:4 where I would expect it to be at least at 1:100. This is a large University campus & when I check the measurement of the grid the distance between is 1000 which is correct.
    Units are set to unitless.
    Any help appreciated
    AUGI Addict tedg's Avatar
    in the upper right corner
    2,287
    Default Re: Scale Issues
    Quote Originally Posted by lesleys View Post
    I'm not quite sure of your actual issue, is the text not at a proper size (scale) in PS when you zoom 1:4?
    The plan doesn't fit in the viewport?
    What units is the drawing in? Metric? Imperial?
    Decimal units where 1 unit = 1 foot? (civil)
    Architectural units?
    1:4 viewport scale doesn't sound quite right for a large scale plan.
    Can you post a sample of the drawing along with more info?
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
    2010-06
    41
    Sorry for not making it very clear.
    The units are "unitless"
    Type is Decimal.
    In model space the campus layout is drawn @1:1 & if I measure the grid the length between pints it is 1000 which is correct. also I have done a dist on several lengths we know to be correct & they are as they should be.
    Also in model space, when I check the size of text instead of being something like 200, 250 which is what I would expect the text height is something like 4.0
    I have checked that the text style is not annotative.
    I tried adding text at what I would consider "normal" size & it was huge!
    Switch to paper space & I want to set the vieport at 1:100 on an a0 layout. Result is a very small drawing, to get it to look like I think it should be I have to set the scale at 1:4 which as you say is not correct.
    Unfortunatly I am not able to post the drawing for security reasons.
    Thanks for your reply I hope this is a little clearer.
    Forum Manager, Administrator Ed Jobe's Avatar
    4,776
    Make a copy of the file and delete any identifying geometry. Maybe leave a rectangle representing the size of the building. Then post that.
    2006-12
    1,495
    Are the model space units meters or millimeters? Paper space is always "paper" size, which is inches (imperial) or millimeters (metric), so you need to account for that additional scale factor if you are going from meters in model space to millimeters in paper space.
    If you are going to fly by the seat of your pants, expect friction burns.
    Windows XP is now over 10 years old, in software terms it makes Joan Collins look like the new kid on the block. - Statler
    Everyone else being wrong is not the same thing as being right.
    0,0,0 The Origin
    8,024
    If you expect to use 1:100 but need to use 1:4, the ratio between them is 1:25 which makes it look like there is a mm/inch translation happening somewhere.
    Check that the paperspce/layout border is actually the size you think it is, not 25.4 times bigger.
    Check the values of dimscale and dimlfac whilst the correct dimstyle is set active.
    Check layout plot scale.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2010-06
    41
    Thanks for your replies. I have checked both dimscale & dimlfac both are set to 1. Also I looked in the original dwg where I have changed nothing & in the dimension settings the alernative units are set to 25.4. This was what you thought was happening. I also checked the plot units & these are set to metric.
    The drawing border is scaled at 1 & is a block.
    Again thanks to all for your inputs much appreciated.
    2004-08
    Hartford, Michigan
    3,086
    If you can't post the dwg, what about a screen shot?
    All AUGI, all the time Statler's Avatar
    2002-01
    At right angles to reality
    511
    Have you measured the dims of the border just to make sure it hasn't scaled?
    Is the model in metres, 4xp would equal 1:250.
    Richard
    Some Days it's not even worth chewing through the restraints.
    2010-06
    41
    Thanks to all those who replied. I never got to the bottom of this as everything in paper space was as I expected. However I am pleased to say that we have done what we needed to do with the drawing so I don't think I need to keep scratching my head any longer!
    Thanks again for all your help.
  1. Annotation families - scale issues
    By crispin.schurr in forum Revit Architecture - Families
    Last Post: 2010-07-26, 11:35 PM
  2. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 07:17 PM
  3. Mtext Scale Issues
    By peter.giampa in forum AutoCAD Annotation
    Last Post: 2008-08-07, 06:15 AM
  4. Scale issues
    By bskripac in forum AutoCAD Plotting
    Last Post: 2005-04-12, 02:32 PM
  5. On Line Design Center scale issues
    By lkarahalis in forum AutoCAD General
    Last Post: 2004-11-02, 04:54 PM
