Results 1 to 10 of 10
Thread: 3D PIPE NETWORK
    2010-04
    53
    Default 3D PIPE NETWORK
    I TRIED TO EXPORT A PIPE NETWORK TO CAD, BUT ONLY THE 2D SYMBOLS WERE CONVERTED THE 3D PIPES AND STRUCTURES WERE NOT. ANY SUGGESTIONS? LANDXML? 3DMAX?
    2001-10
    Arizona
    2,337
    Default Re: 3D PIPE NETWORK
    did you use the command EXPORT to Autocad
    did you see the AAECOBJECTEXPLODE command execute at the command line?
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2010-04
    53
    1. setup a SW axonometric viewport
    2. changed the visual style to realistic
    3. ran EXPORTTOAUTOCAD2007
    the result was only 2D linework as seen in plan views. something similar happens with corridors, but I have found exporting to MAX then to CAD does the trick, only did not work for the pipe network. I will check for AAECOBJECTEXPLODE in the command echo, and try to use the C3D OE in MAX
    2001-10
    Arizona
    2,337
    I think you may need to push them out to navisworks and then autocad.
    Be your Best,
    Michael Farrell
    2010-04
    53
    SUCCESS. CIVIL3D TO 3DMAX TO AUTOCAD 2008 THE FINAL RESULT IS POLYFACE MESH SPLIT BY LAYER. XREF THE PIPE DWG INTO 3DMAX AND CREATE A SPECIAL RELOAD PROFILE FOR WHICH ISOLATE THE LAYERS THEN USE THIS MAX FILE TO EXPORT TO CAD FROM TIME TO TIME THROUGHOUT THE PROJECT.
    2001-10
    Arizona
    2,337
    Why are you doing this at all?
    One can take snapshots of 3d pipe network object in the object viewer window right inside C3D?
    Be your Best,
    Michael Farrell
    2010-04
    53
    GOOD QUESTION. SOME OF THE USERS AT MY COMPANY NEED THE ENTIRE MODEL IN SKETCHUP AND VANILLA CAD2008
    2012-08
    Quote Originally Posted by robert.248186 View Post
    I would like to know how you exported your pipe networks from Civil 3D to 3ds Max and then to AutoCAD. Thanks.
    2001-10
    Arizona
    2,337
    On the OUTPUT ribbon panel there is a button for Export to Civil View
    Be your Best,
    Michael Farrell
    2010-04
    53
    TO EXPORT PIPE NETWORK TO 3DMAX DOWNLOAD THE CIVL3D OBJECT ENABLER AND INSTALL IT. THEN XREF CIVIL3D DRAWING INTO 3D MAX ON THE REFERENCE MENU TURN OFF ALL LAYERS EXCEPT PIPE NETWORK LAYERS. THE RESULT SHOULD BE A 3D MASSING MODEL OF THE PIPES
  1. pipe network VBA !!!!!!!!!!
    By slashhp in forum Español - AutoCAD Civil 3D
    Last Post: 2010-09-01, 04:25 AM
  2. Hydroflow to pipe network
    By gcameron in forum AutoCAD Civil 3D - Pipes
    Last Post: 2009-09-01, 03:27 PM
  3. Pipe Network template
    By gmatheson.88942 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-01-23, 01:10 PM
  4. Pipe Network Edits
    By eckdahlrd in forum AutoCAD Civil 3D - General
    Last Post: 2006-01-19, 12:59 PM
