Thread: Insert a line feed in Mtext
    2015-10
    215
    Default Insert a line feed in Mtext
    I am trying to add a line feed to MTEXT.
    The existing mtext looks like this: 10000
    I want the resulting text to look like this: 10000
    OEL CD
    If I look at existing mtext that already has two lines the assoc 1 list is (1 . "10000\\POELCD").
    However building the string in lisp with the "\\P" does nothing.
    How can I accomplish this? I have been all over the web and found nothing that helps.
    Programming Moderator BlackBox's Avatar
    5,240
    Default Re: Insert a line feed in Mtext
    (defun c:FOO  (/ e v)
      (vl-load-com)
      (if (and (setq e (car (entsel)))
               (setq v (vlax-ename->vla-object e))
               (wcmatch (vla-get-objectname v) "AcDbMText,AcDbMText"))
        (vla-put-textstring
          (strcat (vla-get-textstring v) "\\POEL CD"))
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    All AUGI, all the time Tharwat's Avatar
    2010-06
    820
    What's if the selection is not a text ?
    2015-10
    215
    Thanks Renderman!
    Tharwat, in this case I don't need the error control.
    5,240
    Quote Originally Posted by Tharwat View Post
    Quote Originally Posted by mikehaff View Post
    Thanks Renderman!
    Tharwat is correct... It is not like me to post code like that.
    Code corrected.
  1. Multi line Mtext to Single line Mtext
    By csiress.154683 in forum AutoLISP
    Last Post: 2013-06-12, 02:21 PM
  2. Insert Blocks in MText
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2009-08-28, 01:37 AM
  3. Replies: 8
    Last Post: 2007-03-12, 02:18 AM
  4. Macro to insert symbols in Mtext
    By tedg in forum AutoCAD General
    Last Post: 2006-10-17, 08:00 PM
  5. Insert hard return in Mtext
    By luckyguy5603 in forum AutoLISP
    Last Post: 2006-02-01, 04:28 PM
