Thread: How to convert a cloud points to a solid?
    2012-05
    Default How to convert a cloud points to a solid?
    Hi Autocad experts, i need your help...
    I have a XYZ cloud points in txt format. These points are describing the two surfaces of a 3D lens and both are asymmetrical. I would like import these points to Autocad, to make two surfaces and extrude one to another to create a solid. So, I would like suggestions about how to make this task. The file attached show what I've done so far. Thanks a lot!
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Default Re: How to convert a cloud points to a solid?
    Quote Originally Posted by tiagojk11486128 View Post
    Shoot, I knew there was a shape extraction tool out there somewhere... looks like it was taken out of Labs earlier this year...
    http://labs.autodesk.com/utilities/s...ction_autocad/
    I haven't heard where that functionality might be found yet... While point cloud functionality was enhanced a bit with 2013, shape recognition wasn't part of that.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2006-12
    1,503
    An add-in from Kubit might be able to do this.
    If you are going to fly by the seat of your pants, expect friction burns.
    Windows XP is now over 10 years old, in software terms it makes Joan Collins look like the new kid on the block. - Statler
    Everyone else being wrong is not the same thing as being right.
  1. Convert solid to hatch pattern?
    By dsthilare in forum AutoCAD General
    Last Post: 2008-10-10, 06:07 AM
  2. Convert a Mesh to a 3D Solid
    By agutierrez in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-12-06, 08:11 PM
  3. Replies: 2
    Last Post: 2006-01-31, 03:54 PM
