Thread: Beam line Thickness
    2008-09
    136
    Thumbs down Beam line Thickness
    Can anyone tell me why my beam line weights unbelievably thick ? I’ve tried everything from visibility graphics to object styles and still the beam line weights is huge.
    The only thing I can do is override graphics but I don’t want to do that for every beam. Some kind of settings must be wrong within the template.
    Has anyone experienced this before ?
    2008-09
    136
    Default Re: Beam line Thickness
    Ok i found out why it was giving me huge thick lines, i had a beam filter so i just removed it.
    2002-09
    Madison, WI
    4,440
    In your object style settings, there's a category for each type of beam (girder, joist girder, joist, bar joist, horiz brace.....). You can set the lineweights and types for each.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
  1. Showing line thickness clearly
    By prodrafter in forum AutoCAD General
    Last Post: 2008-08-22, 10:10 PM
  2. LIne thickness question...
    By Ogre in forum AutoCAD General
    Last Post: 2007-08-21, 03:43 PM
  3. Different Line Thickness's between Layouts
    By neilcheshire in forum AutoCAD LT - General
    Last Post: 2006-11-24, 05:46 AM
  4. Changing Line Thickness
    By .chad in forum ACA General
    Last Post: 2006-05-03, 06:00 PM
  5. Line thickness
    By methost in forum AutoCAD General
    Last Post: 2005-10-03, 02:28 PM
