Tib
Sloped Roof Framing:
Place a structural floor (roof decking). Set the floor slope (slope can be set later)
Cut a section and set the work plane to the bottom of the deck. Revit will prompt you to go to a plan view. Pick the view where the new floor was created.
Beam command: Select 3D Snapping.
Place perimeter Beams by drawing in the Beam line, picking edge of the deck first.
Place beam system for interior members.
Adjust the beams elevation (if joists are used) to allow the joist seats to sit on top.
I use Z direction: other. This way I have only one elevation to deal with.
After the floor slopes all the framing should follow.
Test to see if a member is actually attached to the decking by clicking the member and in the properties, Work Plane will state the type of floor it is attached to. If the Work plane is not visible, then the member is attached to the level and not the floor.
