Thread: Spiral Baluster/Wall cut off
    2009-12
    4
    Default Spiral Baluster/Wall cut off
    I'm wanting to create a wall that''s base follows the rising curve of a spiral stair. I also want the top of this wall to terminate at the level above so that is neatly lines up with curved wall above. Currently I'm using a modified rail profile to create the wall. The problem arises when I attempt to terminate the wall/rail to level above as 'rail family' it is not ''cutable''. I have also tried using the curved wall/railing as a 'jig' for a 3d sweep but this is problematic because the the profiles i attach to the 3d sweep do not sit 90 degrees to the floor and so I get a really distorted wall (great if your Frank Gehry). The modified rail option seems the best because is uniformly follows the stair profile. Is there some trick/work around to getting the rail/wall to terminate/cut with the level above?
    Revit BIM Consultant Alfredo Medina's Avatar
    2008-05
    Miami, FL
    986
    Default Re: Spiral Baluster/Wall cut off
    It would be good to see a sketch of the desired result. However, I think it can be done with a couple of surfaces, and then wall by face.
  1. Baluster, Baluster - Post and Baluster - Panel
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2009-10-15, 03:27 PM
  2. Spiral wall
    By Mark Vorstenbosch in forum Revit Architecture - General
    Last Post: 2006-06-09, 11:48 AM
  3. Spring/Spiral Wall
    By willem.92199 in forum Revit Architecture - General
    Last Post: 2006-05-19, 10:52 AM
  4. Spiral wall
    By passerpawn_tech in forum Revit Architecture - General
    Last Post: 2005-12-30, 08:18 AM
  5. Spiral wall
    By passerpawn_tech in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-12-26, 03:55 AM
