View Poll Results: Could RPC Families solve the Fat Family dilemma if they were free and available from manufactures?
Voters
7. You may not vote on this poll
  • Yes
    6 85.71%
  • No
    1 14.29%
Thread: Could RPC Families solve the Fat Family dilemma?
    2016-01
    Nashville ,TN
    90
    Default Could RPC Families solve the Fat Family dilemma?
    Darn those overly modeled Revit Families that I downloaded off that manufacturer's site. Suddenly your Project slows to a craw and your BIM manager is letting you have it.
    In comes RPC. If you have Placed an RPC Family, you may have noticed how small these Families are and how well they Render. All they need are Masking Regions and some Lines to make them work for your 2D Views (construction documents)
    The image below shows two Steelcase Think Chairs. The Chair on the left is the RPC (450K) version while the one on the right is the one actually modeled in Revit (850K).
    Keep in mind that this could potentially mean a huge shift in how firms use Revit with thousands of new RPC Families freely available from manufacturers. One would still need an RPC software license to Render the content but not to use its 2D Views made of Masking Regions and Lines. RPC software licenses are currently $249/ year
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Could RPC Families solve the Fat Family dilemma?
    I love RPC families, they are well worth the $400/year. Note you can easily make your own with the RPC creator.
    Scott D. Brown, AIA
    BECK
    2016-01
    Nashville ,TN
    90
    I think this technology could extend itself to lots of Revit Categories like Furniture and Plumbing Fixtures as well as many Sub-Categories of Specialty Equipment.
    2016-01
    Nashville ,TN
    90
    The image below shows Furniture Families with RPC Families Nested. They are each about 450 K and use Masking Regions and Symbolic Lines for Plan Views.
    2008-09
    Nebraska & Iowa
    378
    What about non-rendered 3D views we use showing the "look and feel" of the space next to our 2D drawings? Would they just be squiggly boxes? <-- like how RPC trees show up
    What about power connections to furniture (or other equipment)? MEP-ready RPC's?
    What if we put the RPC (non-wheeled) chair on a sloped floor? Would only half the lines would show up...?
    I'd need to see a bit more dramatic savings in file size than 450 vs. 850Kb. Granted it appears to be half the size but is that consistent for ALL families across the board?
    Keep posting, I'm interested, just trying to ask questions that I know I'll get asked.
    2016-01
    Nashville ,TN
    90
    rbcameron1,
    There are two types of RPC Families
    1. UV Mapped Meshes. This process projects a texture map onto a 3D object (usually a complex mesh like a car).
    There is no Icon “placeholder” for these Families.
    2. Cutouts. This process uses a series of flat 2d images with transparent backgrounds.
    Icons are custom made from two interesting planes
    RPCs Nest into Face Based Families along with a Detail Items (Masking Region) for Plan Views. See Revit Model Style Guide link below for how to create high performance Families.
    http://revit.autodesk.com/Library/RM...Guide_v2_1.zip
    Categories change as long so long as they start from the Generic Face Based Template. See thread below.
    http://forums.augi.com/showthread.ph...mily-Templates
    Face Based Families can reside on ANY SURFACE. Families use an Angle Param to “rotate” to User defined Instance Values (see link to zipped RFA below).
    As mentioned in earlier in this thread, ArchVision it is well worth the marginal fee for rendering. Non-rendered Views do NOT contain watermarks.
    Feel free to download the test RFA below. Please note that Values for the Params named "Keynote" and "OmniClass Number" are from the Revit Genome Project.
    http://forums.augi.com/showthread.ph...Genome-Project
    http://www.erickoehne.com/Nested_RPC_Chair.zip
  1. 2012: Can a Family flex inside another family ? (Nested Families)
    By derek.96018 in forum Revit Architecture - Families
    Last Post: 2013-06-04, 06:39 PM
  2. help to solve
    By sandeep_koodal in forum AutoLISP
    Last Post: 2009-04-30, 09:58 AM
  3. If you help me solve it you get to keep the family :)
    By mhaidar in forum Revit Architecture - General
    Last Post: 2008-01-14, 09:44 PM
