Is there any way to template the Visibility/Graphic Overrides so they are set each time you link in an architectural model and it turns off all the items you do not want to view?
"I thank God for my life, and for the stars and stripes and may freedom forever fly, and let it ring. Salute the ones who died, the ones that give their lives so we don't have to sacrifice all the things we love." Zac Brown Band
I would need them to work independently for Foundation views and framing views
You can do it, but you'll have to set them up for each project since i'm guessing the name of the linked model will change every time.
You wouldn't be able to do it in a template, since the link would need to be there prior to you being able to apply overrides to it.
Once you set them up, you can apply them to any view you want.
Now if you can set up view templates that will turn off the categories in the link the links visibility is based on your project view and not linked view or custom.
As for foundations vs framing, again you'll just need to set up independent view templates for each.
Hope that helps.
Dave Peterson
Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
"The more you know, the less you know, because the more you know you don't know". --M. Lin
David...thanks for the reply, yeah that is how we do it now...I just thought I would ask to see if there was a different way of doing it...keepin it simple...and I forgot to mention it is 2012...any ideas if there are any changes in 2013 for this? I haven't heard of any though.
I don't believe there are any real changes for 2013. They did a few tweaks, but nothing that's going to make a major difference in your workflow.
Dave Peterson
