Thread: Electrical Object Style issues
    2010-01
    75
    Default Electrical Object Style issues
    Hello,
    I am having issues with the object style settings for some of my electrical fixtures, in particular, my receptacles. For some reason they are not taking on the properties set forth in the object styles. I need them to print a heavy line weight as defined in the object styles, however, in plan view the devices do not take on these properties. If I use a graphical override by category in my v/g settings, it does not work either. However, in a section or 3D view, the object styles work. How come they aren't applying in plan view?
    I could stop if I wanted to CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    386
    Default Re: Electrical Object Style issues
    That's because in plan view, your electrical fixtures are not actually shown. They are instead represented by an embedded Generic Annotation family, which is the annotative schematic symbol. In order to control the appearance of these through Object Styles, you have to go to the Annotations tab, and then to the Generic Annotations Category.
    Note: If you want devices from different disciplines (i.e., blue receptacles vs. green light switches) on the same view, then you will have either create View Filters or edit the embedded annotation family and add the lines to a subcategory.
    Corey D.Please let the saying "The only stupid question is the one not asked" not be seen as a challenge to defy it.
    2010-01
    75
    How simple/stupid of me...Thank you so much for your help!
    2012-01
    386
    Not stupid at all. Logically, You would think that the annotation would follow the appearance of the category its host family belongs to.
  1. Electrical BOM Issues
    By erikjenson in forum AutoCAD Electrical - General
    Last Post: 2009-08-15, 04:37 AM
  2. Custom Electrical Symbol Text Style
    By bradg in forum AMEP General
    Last Post: 2008-08-08, 11:04 PM
  3. Revit Electrical Issues
    By lthacker.166474 in forum Revit MEP - General
    Last Post: 2008-04-18, 12:40 PM
  4. Replies: 1
    Last Post: 2005-02-17, 02:12 PM
