Thread: Plotting from AutoCAD 2000 running with XP
    2001-02
    3
    Default Plotting from AutoCAD 2000 running with XP
    Hope someone out there can help me. I have just had my operating system upgraded to XP, since then I have not been able to plot or even preview a plot. I am getting the following error messages and then the program crashes.
    FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 36016fa8h.
    And then
    The instruction at "0x73dd1351" referenced memory at "0x 00000004". The memory could not be "read". Click OK to terminate the program.
    I seem to be able to print from every other program okay. Any ideas as IT are looking even more confused than I am.
    Cheers
    Steve
    2001-03
    13,499
    Default Re: Plotting from AutoCAD 2000 running with XP
    Hi
    Have you tried a repair install of AutoCAD 2000?
    If that doesn't work, try a complete un-install, re-install of AutoCAD 2000.
    A Search on Forums will return plenty of information on how to accomplish the above (if need be).
    Is your AutoCAD 2000 fully updated and patched?
    AutoCAD 2000 - Updates & Service Packs
    Have a good one, Mike
    2003-11
    Blue Springs, Mo.
    117
    Autocad 2000 is not compatible with XP. Check out Autodesk website for compatiblity issues. Our you the administrator on your computer? It works best if you are.
  1. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  2. Se puede instalar AutoCAD LT y AutoCAD (Full) en MS Windows 2000
    By ruben.martinez in forum Español - CHAT
    Last Post: 2008-10-09, 02:38 PM
  3. AutoCAD 2006 Text Editor, restore to AutoCAD 2000 behaviour
    By louis.64641 in forum AutoCAD General
    Last Post: 2007-05-29, 03:58 PM
  4. autocad 2000 lt drawing wont open in autocad mechanical 2005
    By garryh in forum AutoCAD Mechanical - General
    Last Post: 2005-06-21, 10:02 PM
  5. Plotting Lineweights using AutoCAD 2000
    By mkunko in forum AutoCAD Plotting
    Last Post: 2004-10-29, 10:50 AM
