Thread: Beginner Question...
    2012-04
    Western Nebraska
    8
    Default Beginner Question...
    When I hover over an object in C3d, it used to highlight that entire object (i.e. a line) without physically clicking it. Now it is not doing that. It was useful, and would like to get it back.
    What setting did I mess up to turn off highlighting of an object?
    Rollover tooltips still work, and those are not my issue.
    Thanks,
    Garrett
    2012-04
    Western Nebraska
    8
    Default Re: Beginner Question...
    Looks like possibly AutoDesk 360 was messing with that setting. Signed out and used restore settings option, and now hovering is back. I have no idea why?
    2001-10
    Arizona
    2,337
    Quote Originally Posted by garrett.wynne190200 View Post
    consider it a benefit of working with the cloud
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    Houston
    7,543
    Well, it wasn't really 360 "messing with it". When you signed out and chose to restore settings, it did just that - restored your settings prior to 360 downloading whatever settings are saved in the cloud.
    So the actual setting in question here is the system variable SELECTIONPREVIEW. It was probably set to 1 or 3.
    You can also find this in OPTIONS, on the Selection tab, lower left corner.
    2012-04
    Western Nebraska
    8
    That looks like the culprit. Thank you rkmcswain. I don't recall messing with that option though...dang newbies!
  1. Beginner question about references
    By EDDemtec in forum Dot Net API
    Last Post: 2011-09-22, 06:14 PM
  2. help(Beginner)
    By mohsenmaleki in forum AutoLISP
    Last Post: 2010-11-02, 09:32 AM
  3. MEP beginner question: Mechanical "Layout Path" button
    By sven.129574 in forum Revit MEP - General
    Last Post: 2008-01-28, 11:44 PM
  4. Beginner VBA-ACAD Question
    By svg108 in forum VBA/COM Interop
    Last Post: 2007-09-20, 02:18 PM
  5. Beginner Question - Wall Joins, Wall Ends
    By jalexander.108656 in forum Revit Architecture - General
    Last Post: 2006-03-24, 06:33 PM
