Thread: Help w/ Part - why cant I try a spline/ Curve?
    181
    Default Help w/ Part - why cant I try a spline/ Curve?
    Guys, with a lot of efforts and lots of reading here I was able to mode a part:
    I made a rectangle and swept some profiles along to create some grooves, the profile I drawn in red.
    I want to remove the portion that is in pink from the point to the red line #1, so that I am left with an outline represented by the blue line.
    I have started a new sketch and projected the yellow curves from the model and drawn in a line like #1. however I am unable to trim the yellow curves EVEN after I disassociate them from the part they are projected from.
    I am thinking that I want to create a shape like #2 drawn in black and for an extrusion to cut out what I do not want. However I m not successful.
    However while the 2 distance chamber was able to give me close results, it is not what I want. I need the resulting edge to be parallel to the holes a specific distance.
    Any ideas?
    Williamsport, PA
    606
    Default Re: Help w/ Part - why cant I try a spline/ Curve?
    Attach your ipt file here.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    181
    Here you go, thank you.
    PART TEST.zip
  1. 2011: Edit part in context while part is open?
    By gerrard.hickson in forum Inventor - General
    Last Post: 2011-09-19, 05:02 PM
