AS USUAL GRADING OBJECTS CRASHED MY DRAWING AND IT COULD NOT BE RECOVERED (ALSO AS USUAL) THE WORK AROUND I HAVE BEEN USING IS TO COPY THE PROJECTION LINE OF MY GRADING OBJECT TO A SITE CALLED "TEMP" MANUALLY REDRAFTING THE INTERNAL LINES THEN DELETING ALL PROJECTION GRADINGS, AND RECREATING THEM WITH INFILL GRADINGS, THEN RESTYLING THE INFILL GRADING TO LOOK LIKE A PROJECTION GRADING. BUT THIS IS TOO MUCH WORK. IS THERE A BETTER WAY. LETS BE REALISTIC, I CANNOT USE PROJECTION GRADING ANYMORE, THE RISK OF A CORRUPTED FILE IS WAY TOO HIGH, LIKE THE DRAPED SURFACE WHICH IS PERPETUALLY ROTATED BY 90 DEGREES, THIS IS ANOTHER LOVELY "FEATURE" OF CIVIL3D THAT NOBODY CAN ACTUALLY USE IN A REAL-WORLD OFFICE B/C IT JUST WASTES TIME.
