Thread: Some grid lines disappear in some views
    Active Member AUGI Strangelove's Avatar
    2008-04
    62
    Default Some grid lines disappear in some views
    Greetings,
    I just opened a 2012 project file and all of the "vertical" grid lines are not showing up in plan views. They are still there, as they are visible in elevation views.
    Very puzzled.....
    2002-09
    Madison, WI
    4,440
    Default Re: Some grid lines disappear in some views
    My guess is that the 3d element of the grid line isn't within the cut plane. Open an elevation view from a direction perpendicular to the grids that go missing and make sure that the grids cover the extent of the building (top to bottom).
    My only other guess is that the category is turned off or someone use the "Hide element in view".
    To find out, use the light bulb tool to turn everything on in a view where the grids don't show up. After turning on the light bulb, you should be able to see them (I think the default color for objects hidden is a reddish pink). Select one of the grid lines, right click and see if you get the option to "unhide object in view" or if you're only option is "Unhide Category". This should help figure out what method may have been used.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    You also might look and see if there are some scope boxes that are limiting the visibility of a grid to certain views. select one of the grids that is only visible in an elevation view, right click for properties and look to see if that grid is associated with a scope box.
  1. views disappear on CAD export
    By moliva in forum Revit MEP - General
    Last Post: 2011-09-28, 04:50 PM
  2. Views appear to disappear from project
    By kanderson in forum Revit Architecture - General
    Last Post: 2010-07-30, 02:12 PM
  3. grid bubbles -disappear?
    By pshupe.159931 in forum Revit Architecture - General
    Last Post: 2010-03-16, 07:56 PM
  4. Construction Grid Lines and Grid Dimensions..angles columns
    By persianize in forum Revit - Student Support
    Last Post: 2009-01-02, 09:52 AM
  5. Grid Head / Grid lines on separate export layer
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-10, 09:02 PM
