Results 1 to 7 of 7
Thread: Can Thermal Properties be accessed from a schedule?
    2011-07
    UK
    21
    Default Can Thermal Properties be accessed from a schedule?
    Now that we have the U-values calculated for walls etc by Revit 2013,
    how can we access that data to make use of it?
    I need to do Area Weighted U value calculations for the UK building regulations, which would now be relatively easy if I could access that data in a schedule...but how?
    I don't see anything relevant in the Available Field List when creating a schedule.
    2002-09
    Madison, WI
    4,439
    Default Re: Can Thermal Properties be accessed from a schedule?
    I believe you would need to make sure those shared parameters are in your project before you can extract them.
    Just a thought. But I know it can be done. Our reseller just gave us a little presentation on it. Didn't get into it to deep, but I know it's possible. Weather or not you can get all the info you need in your schedule may be another story.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    AUGI Addict jsteinhauer's Avatar
    2007-09
    Madison, WI
    1,028
    Robin,
    This is done in the materials properties dialog box. Edit the structure of the wall and assign the thermal asset for each wall layer accordingly. Revit will calculate the total R & U value for the wall.
    I hope this helps,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    100 Club Overconstrained's Avatar
    2005-05
    Hamilton NZL
    157
    You can then schedule that information in a wall schedule. The Thermal resistance is available as a field.
    Senior Architectural Technician
    Dean Burdett
    SEKTA Architects Ltd.
    2011-07
    UK
    21
    Thanks for the input, that solved it.
    2009-06
    70
    Is anyone using this as a tool during design development? I haven't had a chance to try it out yet, but it sounds as though you could use the wall schedule to quickly look at the thermal performance impact that different design scenarios would have on the project.
    - Alex
    2002-09
    Madison, WI
    4,439
    We've been using some of the energy modeling tools (add-ons) for revit, so yep, we do that.
    Dave Peterson
  1. LM Tools on a 32 bit accessed by 64 bit
    By julioverde in forum Networks
    Last Post: 2011-12-02, 01:43 PM
  2. 2012: Editing properties quickly from a schedule
    By philipdurban in forum Revit Architecture - General
    Last Post: 2011-11-09, 03:50 PM
  3. Worksets Problem - Accessed by Someone else
    By jrostar in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-04-13, 08:42 AM
  4. filters in schedule properties
    By jacek.brzezowski in forum Revit Architecture - General
    Last Post: 2008-10-20, 10:08 AM
  5. schedule properties
    By rkc in forum ACA General
    Last Post: 2006-12-14, 02:48 PM
