Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Dim Text Above the Dim Line
  1. #11
    I could stop if I wanted to Tharwat's Avatar
    2010-06
    478
    Default Re: Dim Text Above the Dim Line
    That's correct irne'
    My code also would behave as a temporary solution and when any modification would take a place on the dims , they would
    go back to their previous shape ( according to dim style settings ) and that's odd isn't it ?
    Thanks
  2. #12
    2007-07
    Jo'burg SA
    4,344
    Quote Originally Posted by Tharwat View Post
    Not exactly "odd" I'd say. The block is simply a temporary thing which is recreated each time a change is made the the Dimension object. So every time a change is made to the dimension the entire block-definition is redone from scratch, thus your changes are deleted.
    Actually I've just found another way of doing it ... use the XData for overrides. No need to fiddle with the exact text position, and no need to go into the block's definition. Also no need to even worry about other DimVars / Scaling / UCS / etc.
    (defun c:DimTxtMoveUp  (/ en ed)
      (princ)
      (while (setq en (entsel))
        (setq ed (entget (car en)))
        (cond
          ((wcmatch (cdr (assoc 0 ed)) "DIM*")
           (entmod (list (assoc -1 ed)
                         (list -3 (list "ACAD" '(1000 . "DSTYLE") '(1002 . "{") '(1070 . 77) '(1070 . 1) '(1002 . "}"))))))
          (t (princ "\nThat's not a dimension, try again."))))
      (princ))
    (defun c:DimTxtMoveDn  (/ en ed)
      (princ)
        (cond
                         (list -3 (list "ACAD" '(1000 . "DSTYLE") '(1002 . "{") '(1070 . 77) '(1070 . 4) '(1002 . "}"))))))
      (princ))
  3. #13
    2006-04
    (0,0,+|Z|)
    1,119
    Quote Originally Posted by irneb View Post
    ...You're modifying the temporary block of the dim object, as soon as anything changes on that dim (e.g. stretch) these edits are all gone.
    Exactly!
    And thanks irneb, for your last code. It works perfectly.
    But I haven't learned into the "1000", "1002" and "1070" codes yet.
    Could you tell me where to find those info in the "HELP"? Thanks again.
    Thanks to Tharwat, too.
  4. #14
    2007-07
    Jo'burg SA
    4,344
    First look at xdata: http://docs.autodesk.com/ACD/2011/EN...7a53f-7a08.htm
    Especially the organization section, but also retrieval & attach. Then you need to add xdata sections for each of the settings you want to override. E.g. to override the text height to 100.0, this is governed by DimTxt, which in turn is saved as code 140 in a DimStyle.
    And then to override the arrow size to 100.0, this is DimAsz, which is code 41 of the DimStyle.
    So the XData should look something like this:
    (-3 ;Start of the XData DXF section
      ("ACAD" ;ACAD registered app section
        (1000 . "DSTYLE") ;DimStyle sub-section
        (1002 . "{") ;Group the next together
        (1070 . 41) ;An integer (16 bit) to reflect the DXF code of the DimAsz override
        (1040 . 100.0) ;A real value for the DimAsz override's value
        (1070 . 140) ;An integer (16 bit) to reflect the DXF code of the DimTxt override
        (1040 . 100.0) ;A real value for the DimTxt override's value
        (1002 . "}") ;End of group
    Notice the overrides are similar to the DXF codes of the DimStyle itself (this is something for DimStyles though, other stuff may work in other ways). Then in the XData each dxf code is placed in a 1070 (16bit integer) item followed by an item pertinent to the value's type (according to the XData Organization).
  5. #15
    I could stop if I wanted to pbejse's Avatar
    2010-10
    395
    Very nice!
  6. #16
    2006-04
    (0,0,+|Z|)
    1,119
    It is great!
    Thanks again, irneb.
  7. #17
    2007-07
    Jo'burg SA
    4,344
    You're all welcome. And it actually showed me how to do this ... never used xdata overrides before, so this was a learning experience for me as well.
  8. #18
    2006-04
    (0,0,+|Z|)
    1,119
    I always learn something from you with your helps.
    Thank you and I am very appreciated.
  9. #19
    2006-04
    (0,0,+|Z|)
    1,119
    Hi irneb,
    In your code, how to add a localised variable "dimTadValue" to the list? eg
    '(1070 . DimTadValue)
    So it will moves the dimtext up or down when the user changes the value of "DimTadValue".
    It doesn't work as it returns an error message:
    ; error: bad DXF group: (-3 ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 77)
    (1070 DimTadValue) (1002 . "}")))
    I have no problem with predefining the "DimTadValue".
    Thanks for your help.
  10. #20
    2007-07
    Jo'burg SA
    4,344
    If you want to generate a pair from a variable you need to use cons instead of quote ('). Something like this:
    (setq DimTadValue 4)
    (cons 1070 DimTadValue) ;Returns (1070 . 4)
    Using the quote will not evaluate the items in the list into their values. So using the following:
    (setq DimTadValue 3)
    '(1070 . DimTadValue) ;Returns (1070 . DIMTADVALUE) not (1070 . 3)
  1. Line based text - remove text masking?
    By blumarble in forum Revit Architecture - General
    Last Post: 2012-01-04, 05:20 PM
  2. Line spacing In Multi Line Text
    By STHRevit in forum Revit Architecture - General
    Last Post: 2008-09-22, 09:59 AM
  3. Replies: 8
    Last Post: 2007-06-27, 09:09 PM
  4. Convert single line text to multi line text?
    By civilguy in forum AutoCAD General
    Last Post: 2006-10-11, 11:37 PM
