Thread: Bended Coil
    2006-04
    (0,0,+|Z|)
    1,126
    Default Bended Coil
    I am trying to create a bended coil.
    I use the bend mathod after creating a coil.
    But it doesn't look good and the profile of the wire changed.
    Please see the attached file
    What is the better way to do this?
    Thanks for your help.
    2012-06
    12
    Default Re: Bended Coil
    An option to do this is to create multiple 180deg coils, attached to each other. So the end point of one coil is the begin of an other, with every next axis under an angle. I did a quick example of it, see coil_bend.
    Rob.
    2006-04
    (0,0,+|Z|)
    1,126
    I can't open the drawing as I have v2011.
    Can you send me a v2011 format?
    2012-06
    12
    Sorry, I can't save the file to IV2011 but i did make a screenshot.
    Here you can see that i made 4 coils from only 180degr. And the axis is rotated with every coil. The red points are the endpoint of one coil and the begining of an other.
    Rob.
    2002-10
    Pflugerville Texas
    30
    A suggestion might be sending the file (Coil bend) as a .dwf, at least they could see the 3D file.
    2006-04
    (0,0,+|Z|)
    1,126
    Quote Originally Posted by robvanderveek455582 View Post
    Rob.
    Thanks Rob.
    The screenshot is pretty good enough as I can see how you construct the bend.
    You create the 10degree bend with 2 portions.
    In this way if I need a 180degree bend I have to create 36 portions of 5degree bend part.
    And by doing this an iam file would be a time-save solution.
    But all these are not what I am after.
    I think there should be a simpler way to create the such simple part in an ipt file.
    May be there is a trick I have learned.
    Again, thanks for your help, Rob. Any other thought?
  1. 2012: Coil
    By wpeacock in forum Inventor - General
    Last Post: 2011-07-17, 05:16 PM
  2. Coil Module
    By KGC in forum Revit MEP - General
    Last Post: 2011-04-20, 04:58 PM
  3. Coil constraints
    By dpopek in forum Inventor - General
    Last Post: 2008-03-13, 12:49 AM
  4. Rectangle Coil
    By burninin1 in forum Inventor - General
    Last Post: 2007-06-21, 08:44 PM
  5. compress a coil
    Last Post: 2005-04-27, 02:52 PM
